Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 11-12-2017, 12:05 PM
Rockpolice Rockpolice is offline
Default S6L gpi input
Does anyone know if I can connect the grounds together already at the sending end? Manual says the pins are connected together internally so I'd guess yes? Just wondering if I can use a 8+1 cable instead of 8+8 cable.
Thanks, Ilkka
Music business is serious business.
Old 12-01-2017, 02:13 AM
Valentyn Valentyn is offline
Default Re: S6L gpi input
Originally Posted by Rockpolice View Post
Thanks, Ilkka
AFAIR I used to connect grounds together when I did my GPI
M-Audio Fast Track Ultra fisical input 1 appears in VST input 2 blackpauldays FireWire & USB Audio Interfaces (Win) 0 07-19-2016 08:43 AM
Issue Recording Vocals PT12/MBox Pro 3 Input 03 (rear panel) - Works with input 01 lnc77 Pro Tools 12 6 03-28-2016 01:18 AM
Auto input/input only monitoring failing in PTLE 8.0.4 miketeachesclass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-11-2012 08:48 AM
New to MIDI. Input is quantizing. Input Quantize is disabled LiamSlack MIDI 0 03-25-2008 08:59 PM
switch auto input and input only monitor with midiprotocol mmestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-27-2003 03:51 PM
