Old 01-16-2020, 02:31 PM
Jazzbass56 Jazzbass56 is offline
Default S1 loses connection
I have a Dock and an S1, the S1 always seems to lose connection, and I have to power down and power back on for it to wake up, I have it connected directly to my Mac Pro late 2013. I have the latest EuCone App, and both Dock and S1 are up to date firmware, it is somewhat frustrating to have to turn on and off.
Anyone else has this issue?
Cheers
Tommy
Intel Intel Core i7-5930K 3.5 GHz Processor
ASUS X99-PRO/USB 3.1 Motherboard,64 GB crucial DDR4 ram
Thunderbolt EX 2
Windows 10 Pro
2013 MacBook Pro Retina i7 Quad-core, 16gb ram.
Mac OSX 10.11.6
Mac Pro (Late 2013)
2.7 GHz 12-Core Intel Xeon E5
Memory 128 GB 1866 MHZ DDR3
Graphics AMD FirePro D700 6144 MB
PT Ultimate 2022.4.0 on Mac
PT Ultimate 2020.12 on Windows
Logic Pro X 10.6
Nuendo 12.0
1_Antelope Audio_Orion Synergy Core Studio
Old 01-16-2020, 08:45 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: S1 looses connection
I always found that my eucon devices liked to be connected via static ip’s....
That being said maybe there are settings on the RJ45 port that are making it sleep ?
Daniel
Old 01-17-2020, 01:59 PM
That being said maybe there are settings on the RJ45 port that are making it sleep?
Thanks for the tip, I have a router I'll try to use that an set up a static IP address for it.
Thunderbolt EX 2
Windows 10 Pro
Mac OSX 10.11.6
Mac Pro (Late 2013)
Logic Pro X 10.6
Nuendo 12.0
Old 01-20-2020, 10:21 AM
Lynn Gräber Lynn Gräber is offline
How did you find the mac address for your S1?
Old 01-20-2020, 10:37 AM
EddieJones's Avatar
Get info in EuControl
Old 01-20-2020, 11:00 AM
Thanks Eddie! Do you recommend static IP for my S1's? I set my Kindle Fire HD10's to static and they are so much more stable. They have not disconnected once since doing this yesterday.
Old 01-20-2020, 12:21 PM
I have tried static Ip address, and I still get the S1 dropping offline
I'm about ready to return the S1, it's more hassle than its worth
Thunderbolt EX 2
Windows 10 Pro
Mac OSX 10.11.6
Mac Pro (Late 2013)
Logic Pro X 10.6
Nuendo 12.0
Old 01-20-2020, 01:18 PM
Is it possible,I'm just an isolated incident? I ask because I got an RMA number to return the S1 but before I do, I still want to try and find a solution
Sometimes the S1 comes on line and works, but more times it does not, the Dock always works
Thunderbolt EX 2
Windows 10 Pro
Mac OSX 10.11.6
Mac Pro (Late 2013)
Logic Pro X 10.6
Nuendo 12.0
Old 01-20-2020, 01:44 PM
What router are you using? Are you using a tablet? Maybe be a silly question, but have you tried a different ethernet cable?
I have two S1's with Fire HD10's, and one HD7 as master. Performance was usable, but spotty until going static with the tablets.
Sometimes the S1's would be seen, sometimes not. Got IP address conflicts, power cycled things a few times. Eventually things would work, then a tablet would go offline and back on.
Things have been solid for two days now.
Old 01-20-2020, 02:16 PM
I'm using an iPad with the Dock, I have no tablet with the S1, I have not tried a different cable, how do you use static IPs with tablets? I'm using the 2 ports directly to the S1 and Dock, from the Mac Pro trash can
Thunderbolt EX 2
Windows 10 Pro
Mac OSX 10.11.6
Mac Pro (Late 2013)
Logic Pro X 10.6
Nuendo 12.0
pro tools loses MIDI connection with 002 Rack kw88keys Pro Tools 11 2 09-19-2015 09:32 PM
002R loses connection 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-07-2008 01:31 PM
002R Loses connection w/PT LE 7.3.1 badseed79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-09-2007 10:17 PM
Pro Tools Loses connection with 002? please help. joeH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-16-2005 12:26 PM
001 loses connection mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-28-2004 08:47 PM
