Old 04-30-2002, 01:17 PM
in10shun in10shun is offline
Default Re: Exported WAV files - wrong header?
I've come up with two solutions to this problem that are eaiser than using Stripwav and SoundForge. Any feedback on these ideas would be appreciated.
1. If you're working in a 24-bit session and you "Bounce To Disk" one of your Bounce Options is Resolution. The default is 24-bit (since you're in a 24-bit session). Normally you'd leave this alone and choose the Convert After Bounce option at the bottom to convert to a burnable 16-bit .wav file. Changing the Resolution option to 16 AND choosing Convert After Bounce will create a file .wav file that Nero has no problem with. I have no idea why this works or if it degrades the quality of the finished product. Again, any input from you pros out there would be great.
2. Use an older version of Nero. I have version 5031 and it'll burn anything, even these pesky Pro Tools files.
Let me know if these suggestions are helpful.
James
Old 05-01-2002, 12:50 AM
Chris Winfield Chris Winfield is offline
Default Exported WAV files - wrong header?
I've had the Digi001 for a while now, and have been using Easy CD Creator to burn exported stereo files onto CD with no problem.
On upgrading my CD burner and switching to Nero v5 to burn CDs, Nero said it could not read the exported WAV files. Exporting stereo AIFF files works fine however.
When a friend took a look at the WAV files, he said that they did not have the correct header, and thus did not conform to the 'WAV' standard. It seems that Easy CD creator is just more lenient about the integrity of the files it uses.
Is this a known problem?
Old 05-01-2002, 12:52 AM
Pako Pako is offline
<font size="2" face="Verdana, Arial">Yes it is...
Search the DUC for "Stripwav".... A solution awaits you.
~Cheers~
|OS 10.2.8|80gb ATA100|120gb ATA100|
|Mac|FW800|DP 1.25ghz|1.5gb Ram|
|PTLE 6.1.2|Digi002r|Digimax|
|Recent PC to Mac convert|
Wrong length when exported to mp3 bbbeejung macOS 0 01-07-2014 09:34 PM
Exported Audio Has A Wrong Tempo nickmadsen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-17-2012 01:13 AM
"POP" at End of Exported Files? Styles Bitchly Pro Tools TDM Systems (Mac) 1 05-25-2006 08:16 PM
Audio files dissappear when using header finder... proverb18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-26-2005 08:39 PM
Mp3 Exported Files terraform 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-06-2002 04:51 AM
