Bar number missing
I was just editing some MIDI drum tracks and noticed that there is no bar 6: It goes from 5 to 7.
I haven't added or deleted any time. I know how to renumber bars but when I try to change bar 7 to 6 it eliminates 5 and 6 in terms of numbering. Any other way to fix this? I'm running PT 12.4. |
Re: Bar number missing
Check your zoom level.
That was one of the first things I did. I'm @ 120 bpm, 4/4 time.
In the edit window it shows this (starting with bar 4): 4|1 4|2 4|3 4|4 5|1 5|2 5|3 5|4 7|1 7|2... The number of beats is correct, but it just skips 6. It's only a pain because I edit MIDI a lot and it can get confusing. |
musicman691,
I checked the Midi Event List: "All" is selected. Here's what I'm seeing: Sorry-Photobucket isn't letting me embed... |
If you look at the track in the MIDI editor do the notes show there?
Can you export the MIDI tracks as a .mid file and email them to me at my forum email address? I can try it here and see what comes up. |
Yes--midi notes are shown. Everything is normal in the edit window except there is no bar 6.
In the midi editor there's also no 6 and the blue lines for the beats are missing for bars 5 and 6. Weird. Just sent you a PM. Thank you. |
Actually you sent me an email and I responded. You need to send the .mid file via your regular email provider to my Verizon email address which is where I got your email.
Just did that--thanks!
Got the file; imported it into a new PT session and I can see notes in the top two tracks as well as the measure numbers in the edit screen. And all notes are seen in the event list. All bar numbers are showing in both the edit screen and MIDI editor.
There's something weird in your timing as shown in the MIDI editor screen. On my system measure 5 is at 0:08 and measure 7 is at 0:12 whereas your measure 5 is at 0:10 with your measure 7 is at 0:12 I would try a complete reinstall of PT and see what happens. Something I noticed is the notes used - is EZ Drummer using standard MIDI drum mapping or what? And the timing - is this something you played in or a preset pattern? If the latter do you have some kind of swing timing going on? |
Avid HD OMNI missing firmware - missing audio interface | Marco Bernardo | Pro Tools HDX & HD Native Systems (Mac) | 24 | 06-22-2022 02:09 AM |
ProTools HD 10.3.6 - iZotope RX3 DlgDenoiser 'missing plugin' isn't missing | paranerd | Pro Tools HDX & HD Native Systems (Mac) | 4 | 10-03-2013 07:39 AM |
Channel Strip, missing number values | Marcel Risberg | macOS | 4 | 08-01-2012 04:41 PM |
Missing fade files, missing audio in resaved sesssions | drygruo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-14-2010 04:56 PM |
iTune blues: Number nine. Number nine. Number nine. | shaggy | Pro Tools TDM Systems (Mac) | 0 | 01-31-2001 08:12 PM |
