Old 12-26-2018, 10:40 AM
TheEdster75 TheEdster75 is offline
Default Exporting Audio (WAV) for a Mixer
Ok, this was super easy when I was using Cakewalk back in the days, but there seems to be different ways of exporting audio for a mixing engineer who isn’t necessarily using Pro Tools.
Let’s say for arguments sake, I have 30 tracks. 10 stereo, 20 in Mono. Stereo and mono all have different panning and what not and some are 100% left and right and sone mono tracks are right down the middle. Guitar distortion effects are printed, as is bass and everything else including stringed instruments and keyboards. The works.
How do I simply export all those tracks at the same time, as they are, as I hear them, both stereo and mono with all the permitters in place into WAV files for a mixing engineer? Volume levels, panning, etc, etc..
I’ve tried YouTube, Google, I just can’t seem to find anything good on it.. if anyone knows of a good video tutorial they can recommend for that, shoot that over to me. I learn a thousand times better by seeing it done, rather than trying to read how do do something...
Thanks!
Edward Fenley
"Either learn to endure, or hire a bodyguard." ~ Bruce Lee
Old 12-26-2018, 11:12 AM
Default Re: Exporting Audio (WAV) for a Mixer
Step 1-create a folder for each song in a handy place. This could be inside the session folder or on the desktop(my preference) or anywhere that makes sense for you.
Step 2-make all audio on every track a single audio file and have them all start at the same time stamp(consolidate to zero is pretty simple).
Step 3-open the CLIPS bin(on the right side of the screen)
Step 4-drag across and up(or down) so you highlight every audio track(they all all show as selected in the CLIPS bin)
Step 5-right-click on the CLIPS bin and choose Export Clips as Files. Choose sample rate and bit depth(matching the session is a good choice) and then choose the destination. Select the folder you made in step 1 and export.
Once finished, check the folder to see if all the clips are there(they will be if you didn't miss a step).
Last word(which should be first) BEFORE you do the export routine, rename all the consolidated clips so the next person to use these files will know exactly what each is(as in Kick in, Snare Top, LdVox, Piano, etc. There is nothing worse than receiving a batch of audio files named Audio_21_EA......
Old 12-26-2018, 11:31 AM
Emi Emi is offline
What??? He doesn’t use pro tools???? Just kidding, I had to say it.
Mac Mini late 2012 i5 | Mac OS Mojave 10.14 | Motu 16A | Motu 828ES | Pro Tools 2019.5 Native
Old 12-26-2018, 12:50 PM
Top Jimmy's Avatar
Dave, while your method is exactly what I would use, the OP here wants to export post pan and volume. In essence, it sounds like he wants to export every track as a unique stem where they can be dropped into another DAW and have the exact same mix at unity. There's no simple way to do this in Pro Tools.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 12-26-2018, 01:13 PM
Originally Posted by Southsidemusic View Post
He is using Pro Tools so what did mean by that comment?
He ”Used” to run Cakewalk, Didn’t say he ”use” Cakewalk now ..
He was jokingly referring to who I would be sending WAV files to, not using Pro Tools..
Edward Fenley
Old 12-26-2018, 01:15 PM
Southsidemusic's Avatar
Southsidemusic Southsidemusic is online now
Hehe saw that later on the larger screen .. Iphone X was not displaying the tapTalk correctly so i deleted my post
Best Regards
Christopher
South Side Music Group
WEBHOME
So how exactly would they turn out with Dave’s method? Volumes all back to 0db and all panning set back to 0?
Edward Fenley
Old 12-26-2018, 01:22 PM
Top Jimmy's Avatar
Yes. Which is typically what a mix engineer wants. I've never had one want me to apply the rough mix destructively before turning the session over.
James Cadwallader
Old 12-26-2018, 01:57 PM
Ok then. Sounds like that’s the way it’s supposed to be then.. Still learning this whole process. Learn something new everyday...
Edward Fenley
Old 12-26-2018, 03:44 PM
amagras amagras is offline
Only solution is to print every track, this can be done in one pass if the track count is not too large when doubled.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Pro Tools 11 - Exporting Audio for a Mixer question TheEdster75 macOS 1 03-02-2018 07:23 PM
Eucon control over M-Audio Profire DSP Mixer/Focusrite DSP Mixer? finkbmx Artist Series 1 12-26-2010 12:11 AM
Exporting audio? yijvapar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-03-2009 04:56 AM
Exporting Audio, best way ?? shanabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-14-2006 08:18 PM
exporting audio zook250 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-03-2005 05:58 AM
