Old 04-24-2013, 06:37 AM
Default command-/alt-plus/minus extends clip to wrong length
I've just posted this because it has been bugging me for years. Would be great if AVID could change this behavior. It's not logical and would be more helpful if it worked as posted here:
http://protools.ideascale.com/a/dtd/...79?submitted=1
This feature comes very handy when fixing B/Gs after conformalizing to re-create 1 frame cross-fades in an A/B tracklay.
Ultimately it would be even better if "preserve fades" finally worked as it hasn't since it's advent in PT7.2 (I think) and now we're almost at PT11. As long as it doesn't I use the above constantly to work around the issue. But that forces me to constantly switch my nudge-grid back and forth.
See here for details:
http://protools.ideascale.com/a/dtd/...des/12867-3779
Cheers,
Frank.
PTHDn 2019.5 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 04-24-2013, 07:14 AM
conleec conleec is offline
Default Re: command-/alt-plus/minus extends clip to wrong length
Voted for this.
Old 04-24-2013, 03:36 PM
Cheesehead Cheesehead is offline
Have I maybe found a solution?
If you make the selection beyond the region, press command + and then keep holding command and press -, the roll out returns to the selected length.
I was able to make this work multiple times.
This isn't a shortcut I'd heard of before though so maybe It wouldn't work in all cases?
Old 04-25-2013, 01:57 AM
Nice catch! Although I'd still vote for changing it to something less weird. Would cut the number of necessary keystrokes in half as well.
Frank.
Old 04-25-2013, 02:55 AM
Thanks for the shortcut Frank, I wasn't aware of that one, I usually just drag stuff out.
I can see some good uses for it.
I agree it should work first time and not need an extra key press, I voted for it too.
Cheers
Martin
Old 04-25-2013, 03:16 AM
Cheers
Martin
It works on lots of things. You can extend/shorten selections with it too, not just clips. Saves a lot of mousing around.
Having said that, I now see the conflict because that short-cut "obeys" the nudge value. It's just that it seem to add the nudge value to the selected length when extending beyond the end of the clip. Would be great if they could prevent the nudge-value from being added to the selection.
Old 04-25-2013, 06:48 AM
joachim's Avatar
joachim joachim is offline
Isn´t "Edit - Trim Clip - End to Fill Selection" doing that? (extend just to the end insertion and not plus the nudge value)
Does not have a shortcut assigned, but may be customized.
PT 11.3.1 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 64GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
HTML code is On
Wrong length when exported to mp3 bbbeejung macOS 0 01-07-2014 09:34 PM
Clip Gain Line on D-Command? Borgbilly ICON & C|24 5 09-13-2012 09:43 AM
Video clip named wrong after capture. 7.2 bug? scott_cannizzaro Post - Surround - Video 3 10-31-2006 07:35 PM
Protools 7.1cs2 MP3 export wrong length.... DJEJCommPro Pro Tools TDM Systems (Mac) 5 12-22-2005 11:27 AM
Expand region length to insertion command......? lobe Pro Tools TDM Systems (Mac) 8 07-13-2005 11:17 PM
