003 Headphone output problem
I have a issue with my 003 - I cannot get any signal from the front headphone jacks. All other outputs work fine. I usually use a separate headphone feed from outputs 7 + 8 so I have no idea how long this has been an issue with my unit.
I have put the 003 into Utillity mode and used the sine test, but no headphone feed there either. Anyone have any suggestions? Thanks in advance Marty |
Re: 003 Headphone output problem
Basic but necessary questions: Have you turned up the trims? Made sure the phones aren't muted are set to an Alt Source? Have you tested the headphones and the 1/4" TRS in other devices to make sure they're working? Set the Output to Analog 1-2 (only those go to phones)? Check your I/O to make sure Analog 1-2 is actually set to output boxes 1 and 2? Is Analog 1-2 I/O path disabled? Do the headphones have their own volume slider?
Headphone output problem on macbook pro BOOTCAMP windows XP Protools 10 | illution | macOS | 5 | 07-06-2016 12:59 PM |
Headphone output problem with C600 | Matt321 | Pro Tools SE and Essential (Win) | 2 | 05-13-2016 04:45 PM |
No headphone jack output - Meters showing output | Hotcrazyfruit | Eleven Rack | 6 | 05-06-2012 12:09 PM |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
Problem w/ 002R Headphone Output | Frank01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-21-2005 08:11 PM |
