Old 12-23-2008, 11:46 PM
scar97 scar97 is offline
Default Tech support utility in PT8
Has anyone experienced this?
I use the tech support utility to clear out databases and prefs with no problem until PT8. When I launch the .exe file now and choose option 2 (i think to trash prefs and DB) It gives a message that it can't find the disk. It lets me retry or continue. I just keep hitting continue (it is like it pauses before each action). It seems to clean them out but I am getting worried that it might do something wrong.
HELP
PS: Is there a new version of this I need to get with ILOK authorization and a WUP charge with 10 CS updates?...Just kidding. I know the drill
"It aint about the stuff you got..If it sounds right you're finished..Burn it!"
For all complaints click here
DAW
Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent
Old 12-24-2008, 12:30 PM
DigiTechSupt's Avatar
Default Re: Tech support utility in PT8
Did you download the version specifically for Pro Tools 8? Are you on XP or Vista? Are you dual-booting?
Avid Audio Tech Support
Support FAQ
Old 12-24-2008, 12:35 PM
Can you send me the link to find the version for PT8? That may be the problem. I am running windows XPSP3
DAW
Old 12-24-2008, 12:40 PM
mykhal c's Avatar
mykhal c mykhal c is offline
is there still an issue with the utility and dual boot systems?? posted awhile back that utility does NOT work on my dual XP system. DIGI said there are/were isuues with dual XP/VISTA systems. where do things stand now?
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 12-24-2008, 12:46 PM
JMS40 JMS40 is offline
Tech Utility for PT 8
Old 12-24-2008, 01:10 PM
Thank for the info. I just downloaded it. Have you used it yet? does it remove all your plugs and render your system helpless?...LOL
DAW
Old 12-26-2008, 09:42 PM
Ok Digi. I installed the tech support for PT8 from your instructions. Now it gives me a black DOS screen instead of a white DOS screen with more options.
I am still having the same problems. This is what happens when I launch the application
http://www.pippinproductions.com/777/777.htm
Then I have to press continue several times. Then I am too acared to do anything else. I did use it on PT7.4 like this with the pressing continue several times and it seemd to delete everything and trash the preference but I don't want to "guess' What it will do.
Thanks,
PIP
DAW
Tech Support Utility Not Working PT9 cuniberti Pro Tools TDM Systems (Mac) 5 09-06-2011 09:57 PM
Tech Support Utility Fail audiogeekzine Pro Tools M-Powered (Win) 2 08-23-2010 08:20 PM
Tech support utility app problems help! scar97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-04-2008 10:30 PM
Pro Tools Tech Support Utility and SP3 sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-10-2008 12:34 PM
Tech support utility tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-04-2007 01:00 AM
