Old 10-29-2006, 02:06 PM
K-TAJUZ K-TAJUZ is offline
Default How do i fade out on pro tools?!
I'm having trouble fading out...
Do i need an add-on or something?
How do i go about fading out something.
Thanks
Lloyd.
Old 10-29-2006, 02:59 PM
nikki-k nikki-k is offline
Default Re: How do i fade out on pro tools?!
Depends on the specific application...
To do a simple fade on the entire mix as a song ends, you have two basic options...
One would be to set the automation on the Master Fader to "auto write" and then play the song toward the end, and then lower the fader when and how quickly you want. Hit stop, and play it back to see if it is good. Undo to try again and clear previous run, or, goto the other way below, and instead of creating form scratch, edit what you have...
Second would be to simply goto the Edit window, be sure you have a Master Fader showing for the Main out (I am assuming stereo, although it really does not matter), and then change the track view for that Master Fader to show Volume. Decide where you want the fade to start, and, using the pencil tool (line mode), click at the start of where you want the fade out, and then drag to the lowest point (-infinite dB will show, but with infinity sign instead of the word), and let go. Yoou now have a linear fade out. You can edit it with the freehand pencil tool if you like.
More advanced, and more time consuming, would be to bounce or render your mix, bring it back in, or into a new session (possibly to also do other mastering type stuff), and then use the Fade tool to create the type of fade out you want.
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
HOW DO I FADE OUT ON PRO TOOLS? K-TAJUZ Pro Tools M-Powered (Mac) 5 02-20-2021 03:02 PM
Automatic fade in and fade out occurring after recording digicake macOS 5 11-05-2013 01:07 PM
Fade-In and Fade-Out on Multiple Disjoint Regions holden Pro Tools TDM Systems (Mac) 2 11-30-2007 01:22 PM
How to apply fade-ins and fade-outs on selected regions? Halstein Pro Tools TDM Systems (Mac) 2 05-09-2007 03:07 PM
HOW DO I FADE OUT ON PRO TOOLS? K-TAJUZ Pro Tools M-Powered (Mac) 4 11-02-2006 08:51 PM
