DB25 Male to DB25 Female Ext. Cable
I'm in the process of rewiring my studio. I've got one DB-25 cable going to my patchbay from my 192 I/O, but is about 18 inches short. I see on Amazon where you can get DB-25 extension cables for around 10 bucks, but I don't think they are shielded properly. Anybody out there got a recommendation for me, versus just buying a longer DB-25 cable?
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
Re: DB25 Male to DB25 Female Ext. Cable
Those cables are not designed for audio use, won't have differential pairs and grounds laid/twisted together, etc. And extra connections never help, so no forget it, just get a proper longer cable. Lots of good source for those.
Also not all "DB-25" cables actually connect all pins, the ones you are looking at are likely designed for RS-232/serial port/modem/printer connections and may or may not connect all pins, may cross over some pins or have extra "null modem" wiring between different pins. |
I'll give another reason to replace with a longer cable; do you really want to add 16 more chances of a broken signal path? Let's face it, DB25 connectors are used to save space, but not because they are robust and solid While I don't usually recommend Hosa brand, I just installed several of their DB25 cables and(so far) they are all working dandy(and are not likely to ever move)
proaudiola.com sells great hand-soldered cables with your custom length
Sweetwater sells different ended db25 audio extentions. I have a few.
Sent from my SM-N920V using Tapatalk |
This one is designed to do exactly what i'm trying to do. Anybody have any experience with this?
https://www.amazon.com/Planet-Waves-...s=db25+coupler
One new cable from Chris at Redco. Sell the short one on Ebay. Chris did all my SSL dl's. He's great.
Mac 5.1,PT10HD, 192's, SSL 4040G+ keithrobichaux.com @keith_robichaux -Twitter,Instagram |
+1 for Redco.
www.montabonsound.com www.29counts.com Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection |
Also, I wouldn´t advise you having this type of extenders, it´s just an extra and dubious contact connection on the audio path. You spent a lot on your converter and cables and now you want to insert a piece of plastic in between. Not the best option in my opinion. I would buy a good quality extra long db25 to db25 cable with the same pinout to replace you´re existing one, going straight from the converter I/O to the patch. I´m assuming that you have a patch with a db25 connector on the back. Alternatively, did you ever considered (if possible) exchanging the position of your 192 on the rack, closer to the patchbay?
Regards, Paulo M MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura Protools Studio 2024.3 |
Re:female voice to male | 2224 | Tips & Tricks | 10 | 01-09-2016 04:22 PM |
Selling Dangerous D box & DB25/trs cable | bonzerboy | Buy & Sell | 3 | 11-10-2014 04:27 AM |
4ft DB25 Cable | Heinz Kohlbauer | Pro Tools TDM Systems (Mac) | 0 | 02-19-2003 05:26 AM |
Anyone know if a Tascam CU/SD105 db25 to db25 will do the job? | juniperjuniper | Pro Tools TDM Systems (Mac) | 2 | 05-22-2002 12:30 AM |
DB25 to DB25 snake | Viditte | ProControl, Control|24, Command|8 | 5 | 03-26-2002 03:03 PM |
