9.0.3 anytime soon?
Any rumblings of when there might be a 9.0.3 to resolve any of the issues (bugs) w/ 9.0.2?
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
Re: 9.0.3 anytime soon?
What bugs would those be?
One issue I have is on the Macbook Pro when the Core Audio Manager crashes in a sleep mode using digi 003 rack+. It doesn't like the laptop to sleep. If it doesn't crash, it stops delivering sound out through the device. A reboot is needed.
2.) Grid Lines in slip mode 3.) Enormous POP when bouncing an MP3/WAV and there is fade automation drawn on the master fader. p
That's not really a bug because AVID states you have to disable sleep mode.
I hope digi doesn't forget about that grid line thing in slip mode?, hey paul_g, dig your setup, I have the same setup as you (LOL), on side question on the FS if I may. seems like you have to really crank up the pres to get good levels on the FS, almost where it says -10db?, I thought it operated at +4?, yes I'm stilling learning (LOL)
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
4) Unbelievably slow audio import, via drag & drop (apparently caused by the 'Home' and 'Net' folders in the workspace)
I hope they remember the promise to make H/W buffer size 2048 again to save going back into PT8 for using Drum Rehab.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3 |
Depends on the mic and the source (what you're recording). Don't be afraid to crank the gain... but if you're not getting the gain you need, you may have to use another pre-amp. I've had great success with the DigiMax, but I do notice on my ribbon mic's that if the source is really quiet (a soft finger picked guitar) I will use my PreSonus Tube Pre's... then I get the gain I'm looking for. Usually for Vocals I always go to the TubePre's and juice them w/ a bit of 'drive'. With that said, don't be afraid to crank them... It's like having a tool box, you need different tools for different things... There isn't a catchall "Leatherman" for this stuff. p
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp Last edited by paul_g; 04-21-2011 at 07:08 AM. Reason: update |
10.4.10 Upgrade anytime soon. | Timebot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-06-2007 06:04 PM |
I give up anytime now | puremusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-26-2006 10:12 AM |
PT6.1 and Panther 10.3.1 anytime? | misterlump | Pro Tools TDM Systems (Mac) | 7 | 01-22-2004 01:52 PM |
win me anytime soon? | epsilon-x | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-15-2000 05:35 PM |
5.01 upgrade - anytime soon.....??? | SvtYeahBaby! | Pro Tools TDM Systems (Win) | 5 | 06-08-2000 07:49 PM |
