AES Mutes
Hi Sheldon,
When I change system settings and the software reboots it mutes the outputs on the stage rack, correct??? Does it also mute the AES outs on the FOH rack? At the moment we have to mute the rig to stop getting a painful crack through the system. |
Re: AES Mutes
Hi James,
Yes, all outputs (analog and digital) are muted on the stage racks. There may be a slight pop on analog outputs when the hardware relay kicks in. The FOH AES outputs are muted when the system settings change. The FOH analog outputs are NOT relay-protected and therefore can produce a pop. Which outputs (stage/FOH, analog/digital) are you hearing the popping on? Sheldon |
mutes - which daw has it right? | musicman691 | General Discussion | 2 | 01-28-2012 02:24 PM |
Is there a way to link track mutes to send mutes? | Ed Douglas | Tips & Tricks | 6 | 01-05-2010 06:39 PM |
Send Mutes to Follow Channel Mutes | Jeff E | Pro Tools TDM Systems (Mac) | 8 | 08-31-2009 08:05 AM |
Disable Mutes? | vze24x2x | Tips & Tricks | 16 | 02-25-2004 10:06 PM |
Mutes gone wild! | orage | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-16-2003 09:42 AM |
