Amp head needed?
May be a silly question... but I've been looking through for a while and can't seem to find a specific answer.
I was looking in to getting an Eleven Rack, but in regards to live performances, I only have a Mesa cabinet, my buddy took back his Marshall head that he loaned to me... so that's gone :/ .... with the power of the 11R, is it possible to route it through the cabinet without any added power?? I'd appreciate your guys' help! Cheers |
Re: Amp head needed?
No, you need an amp, but you DON'T need a guitar amp as any power amp will work fine(and maybe better). My preference is for a power amp designed for guitar(as opposed to a PA power amp). Some options to look at:
MosValve http://www.ebay.com/itm/Tubeworks-Mo...item3ce502e6b0 Mesa http://www.ebay.com/itm/Mesa-Boogie-...item1c436dcdfc Peavey http://www.ebay.com/itm/used-Peavey-...item27e7ca1a32 When you use a guitar amp, you generally disable some or all of the amp modeling in the 11R(which is something it does very well, so why not use it).
Perfect! that's exactly what I needed to clarify.
Thanks Dave!! |
FWIW, I used that same Mosvalve for several years with an ADA MP1, feeding a stereo Marshall cab with 20 watt greenbacks. It was glorious
Awesome! :) Thanks for your help, another quick question.. pre-amps are generally the same as power amps?? probably another silly question, but I'm a drummer, lmao, never researched guitar equipment, but I'm always playing guitar and really getting in to it more nowadays. :)
Thanks again. |
A power amp is what converts your line level signal to the much higher speaker level output to drive a speaker cabinet. Guitar amps (combo amps as well as head/cabinet setups), have both a preamp section and a power amp section before being connected to the speakers. Your 11R is similar to a preamp as far as input and output levels. That is why you need to connect a power amp and then to a speaker cabinet. One other option is connecting your 11R to a powered speaker (which has a power amp and speaker in one unit). I hope that clears it up for you.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Perfectly clear, appreciate it again!! Thanks guys
Head to head shoot out: Matchless D/C-30 vs. eleven rack MS-30 | Chad Pippin | Eleven Rack | 11 | 07-26-2012 07:21 AM |
HEAD TO HEAD - The Amp Simulator Shootout Project | Benoni | Eleven Rack | 82 | 12-25-2011 04:08 PM |
Im in over my head | dunkyj | Post - Surround - Video | 1 | 06-01-2011 03:42 PM |
Low in my head | ^Tripper^ | Tips & Tricks | 2 | 06-22-2005 12:22 PM |
how much head | MR808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-03-2003 09:26 PM |
