Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 05-15-2020, 12:22 AM
unkJE's Avatar
unkJE unkJE is offline
Default Mbox Pro 3 on Windows 10 with Pro Tools 2020.3
This works for me on Windows:
Onboard audio for Pro Tools: Conexant 20672 SmartAudio HD version 8.32.43.0
Mbox Pro Setup
Sample Rate: 48000
Preferred Buffer Size: 64
Windows Sound:
Playback Tab = Onboard Audio (Speakers)
Change Playback Tab to Mbox Pro for CDs, DVDs, You Tube, etc.
Recording Tab = Avid Mbox Pro
Pro Tools Setup>Playback Engine
During Session, change your H/W Buffer Size:
64 Samples for Recording
1024 Samples for Edit/Mix/Bounce, etc.
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Old 05-22-2020, 02:27 AM
ahh_ceh ahh_ceh is offline
Default Re: Mbox Pro 3 on Windows 10 with Pro Tools 2020.3
These settings work for me too.
However, I started getting clicks and pops while vocal tracking very recently.
Possibly since the new update.
Been troubleshooting and tracked the problem down to the interface or a software issue.
(definitely not my external preamp, like I thought. Sometimes I was getting the clicks and pops during playback, but not always)
I'd never had a problem with the Mbox Pro 3 and handling large loads before. Very off.
Running the Duet for Windows now for tracking sessions in the meantime.
Going to try to replicate click and pops while recording vocals with Duet this weekend.
Old 04-30-2021, 01:22 AM
shadyS shadyS is offline
For me, mbox pro is not being read correctly when used as the default sound device on windows 10 ... it can play a few seconds of any audio and then goes silent.. have you encountered this problem?
When i open pro tools it works just fine!
Really annoying when i want to play anything on my speakers (plugged into the mbox) .. HELLLPPPP
Old 04-30-2021, 06:46 AM
unkJE's Avatar
To use another DAW, or to play CDs, DVDs, Podcasts, You Tube, etc., I found it easier & quicker to use another laptop.
Otherwise – I have to restart the Pro Tools computer, which demands that the onboard audio (and not the Mbox Pro) be set as Default Device, in Windows Sound Playback tab.
2nd easiest way:
Quit Pro Tools
In Windows Sound Playback tab, select the 1st option:
Speakers (Avid Mbox Pro) as Default Device
Mbox Pro’s Control Panel – Setup button (3rd from right @ top), select Sample Rate
Increase “Preferred Buffer Size” from low (64) to high (1024)
Load button (1st left @ top) – change your Pro Tools Preset to your Mbox Pro Preset
Turn computer off
Turn Mbox Pro off
Turn Mbox Pro on, then
Turn computer on
Play CDs, You Tube etc
Next time you want to use Pro Tools, reset & restart.
However, if there’s a quicker way, I’m “all ears”!
Old 04-30-2021, 12:52 PM
Best practice for Windows setups is to set Windows to use the on-board sound card as the "default Playback Device", which leaves the interface(M-Box) to be controlled by Pro Tools exclusively. The simple/cheap solution to playing other sounds(WMP, Youtube, etc) thru your monitors is to add a small(cheap) mixer to your setup. All you need is 2 stereo line inputs(1 set for the M-Box outputs and the other set for the soundcard output). This is a suitable option on a budget:
https://www.amazon.com/Behringer-502...9812165&sr=8-2
Another option is to add a monitor/source selector like the Presonus Monitor Station 2, Audient Nero or similar. Yes that's a lot more money, but having used a Presonus central Station for years, I can't live without it(or similar). A real plus is that some of these allow you to connect the computer via a digital SPDIF connection(which sounds 100 times better than the mini TRS analog output)
Old 05-01-2021, 02:32 AM
Thanks a lot unkje for the quick response... i've tried step by step but it's still not working for me :/ i never had any problem with the mini mbox thou.
I think at this point i might follow albee's advice and just buy a tiny mixer for monitoring, but since im also using adobe audition for some projects, i wouldnt be able to use the mbox on it, so thats another issue i just thought of
Old 05-01-2021, 05:47 AM
Ok so i've found a workaround! thought i'd share it for whoever will need it.
Since it can be used as a standalone, i tried this:
After holding the "spkr" button on the MBOX PRO and putting it in stand-alone mode while still plugged into the laptop (spkr button starts blinking), I used an RCA cable plugged in into SPDIF, and connected it with a RCA/AUX adapter to the HEADPHONES mini jack input of the laptop, switched the default playback sound of windows to the laptops sound card (realtek in this case).. and voila :S
Not perfect but works like a charm ! i guess to switch back to pro tools monitoring ill just press on "spkr" and put back the pro tools settings in the mbox control panel
Old 05-01-2021, 09:27 AM
You probably can use the Mbox for inputs to Audition, but it would playback via the computer sound card(make the Mbox inputs available under the Sound Properties Recording tab)
Old 05-02-2021, 01:11 AM
It works when switching back audio hardware from ASIO4ALL to mbox, but can not really hear what im recording unless i switched it back oh well better then nothing
MBOX 2 - Windows 10 or Windows 7... Renan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-03-2018 06:08 PM
MBox 1 and Windows 7 oldboy88 Pro Tools M-Powered (Win) 3 05-11-2012 04:22 PM
Updating Pro Tools and Mbox from Windows XP to Windows 7 ryanjantz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2011 04:22 PM
Original MBox with Windows Vista or Windows 7 JoshuaD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-16-2009 06:57 AM
Original MBox on Windows Vista or Windows 7 JoshuaD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-16-2009 06:50 AM
