Sustain and Protools mp 7.4
Is there a way to set the sustain (see pedal) to be incremental instead of simply on off?
Re: Sustain and Protools mp 7.4
Any help with this please?
A sustain pedal is a non-latching momentary switch, therefore it is only on or off. Maybe your looking for an Expression Pedal, which will allow you to control any assignable variable MIDI controller value. Your keyboard controller will need to have an Expression Pedal input.
Here's an example of an Expression Pedal: M-Audio EX-P Expression Pedal by M-Audio
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM Windows 7 64-bit Pro Tools M-Powered 8.0.4cs2 M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1} Glyph 050Q 500GB via eSATA |
I'm using an axiom pro 61. So you're saying that with an expression pedal I'd be able to control the sustain beside it being on and off in PT?
What I'm looking for is a way to do like I do on a regular piano, and that is control the amount of sustain there is. On a regular piano, if I don't press the pedal down fully, there's is sustain, but not as much as there would be if I press the pedal down completely. That's what I'm trying to do. But in pro tools, with the pedal I have now 9Sp-2) it's either fully off or fully on. If I try to draw the sustain and put it at 64 for example, it doesn't change it as if half on. |
MIDI defines sustain as either on or off. It is not a variable message in the MIDI standard. ≤63 off, ≥64 on.
I did not fully understand what you were asking, that is why I suggested a expression pedal. But, that would only be able to variably control MIDI for variable controllers.
Protools 11 Midi Sustain Issue | joshlmiller | Pro Tools 11 | 4 | 06-10-2017 03:36 AM |
MIDI Sustain Keeps Going and Going | anackman | macOS | 6 | 11-20-2013 05:22 PM |
Why does PT interrupt sustain? | RaySoul | MIDI | 6 | 01-26-2010 09:11 PM |
sustain?? | rishabh | Virtual Instruments | 3 | 05-23-2007 07:45 PM |
Sustain Pedal | stut5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-04-2003 11:45 AM |
