Old 05-29-2009, 06:28 AM
pmueller pmueller is offline
Default Group Stereo Width in Stereo AFL Mode
Hi
While adjusting the audio group stereo width, I can't hear the changes while solo AFL stereo mode is active. It remains in full stereo. Doing the same listening the stereo bus I can hear the width adjustements. Is there anything I do wrong?
Thanks for help!
Patrick
Old 05-31-2009, 09:36 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: Group Stereo Width in Stereo AFL Mode
Hi Patrick,
If I recall correctly this is a limitation of the solo bus - it picks off the AFL feed before the stereo width control.
Sheldon
Old 06-02-2009, 01:12 AM
Sheldon
Is there any chance this issue (bug) will be solved within a future update? We do broadcast mixing/recording and do use it quite a lot.
Thanks,
Patrick
Old 06-03-2009, 12:05 AM
Hi Patrick,
We'll look into it again, but no guarantees it can be resolved. It's a limitation of the internal DSP routing, and I don't expect that much has changed since the original implementation. One workaround in the meantime wold be to use an unused stereo matrix (PQ) as a confidence check: route the audio groups in question to the PQ, and then AFL the PQ. I haven't checked this on a console, but I expect it will work.
Sheldon
Old 06-05-2009, 04:17 AM
Many thanks!
Patrick
Using Air Stereo Width KingTalkJohn Tips & Tricks 7 08-30-2013 05:52 PM
Routing to give a stereo group a stereo plugin on the VENUE plus AES EBU uses somtech VENUE Live Sound Systems 5 05-19-2012 07:43 AM
Getting More Stereo Width hebro1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-19-2012 09:11 PM
No Group Fade Link in Expert Stereo Pan Mode emluper VENUE Live Sound Systems 0 06-19-2010 05:11 PM
Need help with Stereo width... soundfx Tips & Tricks 5 12-13-2006 08:57 AM
