Old 02-09-2014, 03:25 PM
Davi Davi is offline
Default No Playback Through Headphones (Pro Tools 10)
Ok, so for some reason I can't get audio to play back through my headphones in Pro Tools 10 on my laptop.
Both the headphones and the connection are fine (every other conceivable source of audio other than Pro Tools is playing back fine).
Various system sounds are also clearly coming back through the headphones, it's just the Pro Tools stuff which is coming through the speakers still.
  • Playback engine is ASIO4ALL v2
  • The I/O is stating the output as being the speakers (HD Audio Speaker 1-2). I assumed this would automatically flip to 'headphone mode' once a pair was plugged in but maybe I have to guide it to them? (had a look but ultimately i'm not too clever with this).
The only other thing I can say is that I installed the same package onto a separate desktop computer and the playback is fine there.
Cheers.
Edit: I'm using the only headphone jack on the side of my laptop, no mbox or anything; I'm under the impression it should still work without, right?
Old 02-09-2014, 04:48 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: No Playback Through Headphones (Pro Tools 10)
Cheers.
You might need to check your Windows audio settings using the Windows mixer. Is the headphone jack volume control turned on? Did you accidently mute it?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 02-10-2014, 06:17 AM
junkgear's Avatar
junkgear junkgear is offline
You may have to enable the headphone out in the ASIO4ALL configuration.
Since this switches when you plug them in, try plugging in your headphones, then go into ASIO4ALL configuration and enable the headphones as output devices. Then fire up PT and see if it works for you. I'm not sure if you will have to change any settings in PT or not. If the headphones appear as new output devices you may have to tell PT to use them too.
Will
System Details
Old 02-12-2014, 03:42 AM
It's definitely on. As I said there are audible system sounds, such as the 'beep' that plays whenever you alter the volume level, so everything is fine on that front; it's just that Pro Tools isn't cooperating.
How exactly do I get into the ASIO4ALL config?
Old 01-05-2019, 01:55 PM
TheDimSide TheDimSide is offline
I'm having the same problem, too. Were you ever able to get this figured out?
No Audio in Playback or Headphones Bradley54 Pro Tools M-Powered (Mac) 0 01-16-2013 07:13 PM
Playback only through headphones! jikaru 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-10-2008 06:51 PM
Playback in the headphones felix822 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-12-2007 02:33 PM
No Playback through Headphones in Pro Tools 6.1 JSXtremist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-25-2003 11:51 AM
No Playback through Headphones kucharo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 10-04-2001 10:12 PM
