Old 12-16-2018, 02:30 AM
gub gub is offline
Default Note getting Stuck
I'm sure this has been cover.....
I have just got a new Mac and have PT freshly loaded........
When I load up an instrument in PT (latest) and I arm the track the instrument (NI, xpand ect) sound just hangs or pulsates.
Not had this problem before....
Old 12-16-2018, 04:57 AM
Default Re: Note getting Stuck
Some NI vi's have a long-standing issue of stuck notes from time to time. Absynth is one and Kontakt to a lesser extent. Do you have your NI stuff fully updated through Native Access? They may not be compatible with Mojave.
Old 12-16-2018, 03:16 PM
gub gub is offline
It’s not just a NI issue, all instrument plugins......including Pro-tool plugin instruments such as Xpand, Vacuum
I have a feeling it’s just not turning the note off on the plugin.......
Old 12-16-2018, 09:17 PM
gub gub is offline
Fixed with a USB-C Multiport
Old 12-16-2018, 09:52 PM
Eric Lambert's Avatar
A few NI products, and EVERY product from Output has bad issues with MIDI notes not shutting off after receiving note-off messages. Neither company is doing much to fix the issue though both have confirmed that it's an issue.
Old 12-17-2018, 09:28 AM
Keep in mind that Output uses the Kontakt engine for it's products so it's no surprise there's stuck notes with their stuff.
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
EXPORT MIDI from Stryke NOTE FOR NOTE... riggi Virtual Instruments 1 03-10-2008 07:32 PM
stuck note Gtibbs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-21-2008 01:26 PM
Midi note "stuck on" George Siede 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-07-2005 03:18 PM
