Old 10-24-2019, 10:30 AM
skilletaudio skilletaudio is offline
Default Eucon "Left Edit Control" & "Right Edit Control"
Can someone explain the difference between the "Left Edit Control" and the "Right Edit Control?"
"Right Edit Control" does not work at all. There is no documentation that I can find. I have downloaded every what's new guide I can find, all the Eucon manuals and searched and nothing comes up for either of those. Internet searches also yield nothing for me on this.
Old 10-28-2019, 01:11 PM
Default Re: Eucon "Left Edit Control" & "Right Edit Control"
Eddie, perhaps you might know?
Old 11-12-2019, 09:48 AM
Does anyone know the answer to this?
Old 11-14-2019, 09:17 AM
niekbeem niekbeem is offline
Unfortunately I can not say if there is any difference between the 2 commands.
Please refer to this page for an image which -hopefully- makes clear that these commands origin from the time that the MCPro was the only machine EuCon worked on: https://www.rspeaudio.com/Articles.asp?ID=283
Please note the "Edit Control Left"- and "Edit Control Right"-zones.
I think though that nowadays one can assign "Left Edit Control" to functions which can be changed with the wheel? I'm not sure about this, so forgive me if I'm wrong.
This is what "GettingStartedWithEuCon.pdf" tells about "Edit Control Processor"
Edit Control processor
An edit controller processor contains a jog wheel and jog/shuttle mode switches. Applications are encouraged to support as many functional modes for the jog wheel as possible, such as horizontal and vertical zooming, waveform zooming, trimming of clip head and tail, cross fade length, clip gain, time zooming, scrub, slip, fade in and out, and more. Accordingly, the edit controller processor contains a switch array containing switches to set these modes. By convention, the edit controller processor is named “Edit Control”. Some control surfaces support two physical edit controllers, a left and a right. The application can choose to model both controllers, taking full advantage of these surfaces. In such a case, one editor controller processor is named “Left Edit”, while the other is “Right Edit”.
Niek/ Amsterdam.
Pro Tools Ultimate 2023.6 / Nuendo 12 / Logic X / WaveLab 11
MacPro 5.1: 12Core 3.46GHz Intel Xeon/ 48GB RAM/ Mac OSX 10.14
MacBook Pro: 2.9 GHz Intel Core i9/ 32 GB RAM/ Mac OSX 10.14
MetricHalo ULN8 + 2882 / RME HDSPe MadiFace
Euphonix MC Pro
Old 11-15-2019, 07:09 AM
Thank you for that, I should have thought of that I have one of those sitting 2 feet from me but I hardly ever use it. Very appreciated!
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
SOLVED - Dock Left Edit "Shift" greyed out simonchase Avid S1, S3, Dock and Control App 5 03-14-2017 11:50 AM
Alt-Shortcut to reach "Edit" > "Automation" > joachim Windows 0 10-13-2014 08:14 AM
MC Control "eucon library is not loaded windows" djmichaelwenz Artist Series 1 10-05-2012 07:11 PM
"Space" in Edit Window, to the left of Bar 1 ?!? LSNY macOS 1 05-29-2012 07:47 PM
