My 11r clips when the output is turned up
It's INTERNAL to the 11r. It is there. It shows up on headphones, in a PA (and no, the pre's aren't clipping) and it shows up in studio monitors. It is more distorted at 8.5 and up than it is lower than that. It is an internal clipping. It happens when playing, or when listening to music. This means I need to "bit starve" both while I record, listen and play live.
WTF
Affiliations: Line 6, Reverend Guitars, Rockett Pedals, Pedaltrain, Curt Mangan Strings and Lollar pickups. |
Re: My 11r clips when the output is turned up
The culprit on mine about 100% of the time is in the amp output setting (not to be confused with rig output.) Go to the metering screen and you'll probably see it clipping there. You can back that down a nick and suddenly be a lot happier... YMMV...
I'm not using an amp. It's not reading as clipping on the 11r's meters, either.
Texasdave was not talking about the amp output as the output of your amp but rather of the parameter inside the 11R that carries the name "amp output". It's inside the amp's control parameters.
I know that. It's not that. None of the meters are clipping (either when playing or when listening).
Listening now, literally Pat Metheny's guitar is distorting more (digitally) when the main output is turned up AND NONE of the 11r's meters says anything about clipping.
Try turning the volume down in your media player, maybe?
That would show it clipping in the meters, and it wouldn't explain why it clips when playing guitar.
Judging from your answers to the suggestions given, it sounds to me like you know there is something wrong with the 11R, and that it is internal so why not take it in to be tested by a tech?
Is it still under warranty?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
No. I've had it since it came out. It's never suffered a hit or anything, either.
But honestly, I just can't do without it. I do this for a living and I use the 11r constantly these days. I'll just have to make do with a messed up one, I guess.
Exporting Clips as WAVs, clips dont highlight in list | gigantorbuzz | Pro Tools 10 | 6 | 08-05-2013 01:07 PM |
Cross fades are not between clips but at the end or beginning of clips | phatbeatstudio | Pro Tools HDX & HD Native Systems (Mac) | 2 | 09-10-2012 02:08 AM |
Drag Clips = Delete Clips??? | Connor | macOS | 2 | 07-09-2012 07:50 PM |
Editing clips without creating new clips | dimebagslash | Pro Tools 10 | 2 | 07-04-2012 07:24 AM |
