Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 08-30-2019, 09:58 AM
Big Cloud Big Cloud is offline
Default Future updates Question.
Hi, long time Cubase user here who has to use Pro Tools (v. 2019.6, Windows 10) from time to time.
Just updated my PT to 2019.6 and got myself a physical iLok, everything is working OK, only thing I notice that's detrimental compared to Cubase is..
Pro Tools seems much more Ram hungry than Cubase. I've got 16gb RAM and I'm going to upgrade to 32 in the next few days, but running the same session in both CB and PT is a very different experience. I've had a few memory crashes in PT and the ram meter has hit 100% a couple of times (cache set to normal and video engine is off) . The same session with the same Vi's runs perfectly smoothly in Cubase on the same machine.
Midi drum maps. Programming a midi beat in Protools is way more fiddly when you can't load a drum map. Finding the different drum articulations on your keyboard just takes longer in PT.
Apologies if this has been covered a million times before, but I'm not really part of the Avid community, so my question is, are these known issues that are likely to be rectified in future updates, or do most not have these issues?
PC / Win 10 / Focusrite Saffire Pro 40 / Pro Tools 2019.6
Old 08-31-2019, 08:04 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Future updates Question.
First, make sure to do ALL the optimization listed at AVID for your OS. Second, set ram cache about the size of your session audio files plus a bit-"Normal" actually means "off" in this case. Third go to the help us help you section and get a Sandra. Fourth , do the plug in tests outlined in many threads here as it sounds like a possible corrupt plugin or file issue-not ProTools specific necessarily, just affecting PT for whatever reason(such as AAX plugin difference from VST)
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 08-31-2019, 09:03 AM
The Weed's Avatar
The Weed The Weed is online now
Many PT users sequence in Cubase or Logic and mix in Pro Tools. Others use VE Pro to host virtual instruments.
For optimizations suggestions beyond Avid's look here.
And always remember, AVID is DIVA spelled backwards.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 08-31-2019, 09:08 AM
JFreak's Avatar
JFreak JFreak is online now
Janne
Old 09-01-2019, 04:12 AM
And here's a link to a fellow that's been around for ages with Windows optimizations - Black Viper http://www.blackviper.com/
Jack
QAPLA!
I already own 11 HD - what to do about future updates? [solved] PhattBastard Pro Tools 11 3 12-30-2014 09:58 AM
MP9 future updates for Win8 laetidjey Pro Tools M-Powered (Win) 0 04-08-2013 12:29 PM
Future Software Updates? Final Lap Guy Pro Tools Express on Mac OS X 14 10-04-2012 03:31 PM
suggestions for future PT updates EricWillhelm General Discussion 3 08-25-2007 08:20 AM
digi 001. will protools 7 and future updates work? wreckthisplace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-20-2005 04:49 AM
