Old 08-27-2019, 10:18 PM
maxgain's Avatar
maxgain maxgain is offline
Default MIDI Keyboard Sustain Pedal Sticks only when recording
Hello,
New song on ProTools 2019.6.0. When practicing with record enabled, sustain pedal works fine. When tracking the 1st half of the song, the sustain was fine. Now trying to add to the song, EVERY time going into record, the sustain pedal "sticks" and stays on. Reloaded session, rebooted. What gives? Any ideas? Thanks!
Nektar GX61 keyboard. 2013 iMac Mojave 10.14.5.
AudioEngineering.co - Pro Audio Engineering Blog
Pro Audio Engineering Tips • Tricks • Techniques • Training • Free & Discounted Plugins & Software • Live Q&A • Audio Resources • News • Links • Loops • Samples • Stem Files • Mix Contests & More • Visit Today & Share... Thanks!
Old 08-28-2019, 04:01 AM
Default Re: MIDI Keyboard Sustain Pedal Sticks only when recording
Assuming your Nektar & sustain pedal are okay take a look at the MIDI event list for the track in question and see if you don't have an unresolved pair of MIDI sustain pedal events like an on without an off and vice versa.
What vi are you using? Some vi's have a tendency to have a sticky sustain pedal response.
Old 08-28-2019, 09:02 PM
maxgain's Avatar
Thank you... Using EZ Keys, all up to date. MIDI Events show sustain is working OK. Screen shot attached. I imagine if I try to overdub then we'd see the sustain stuck on in events.
File Type: jpg Screen Shot 2019-08-28 at 9.58.45 PM.jpg (21.3 KB, 0 views)
Old 08-29-2019, 02:21 AM
Is this the infamous midi merge bug once again?
Old 08-29-2019, 03:46 AM
What does the MIDI event list show and how's the timing of the events there? The graphic you show doesn't really give timing resolution good enough to judge one way or the other.
Old 08-29-2019, 10:50 PM
maxgain's Avatar
Hi thanks again. I don't think a high resolution is required. Except that I know nothing. But picture this. The sustain pedal comes on and stays on. That's it. I have to stop recording. The take is wrecked. It seems to me to be a gross/major error. The screen shot I posted is it working. I'll do another when it's not.
I didn't want to bring this into it but I've had the very same issue with earlier versions of PT (11, 12) with totally different MIDI gear and VST's. Like, enough to just stop working on the projects back then. Honestly it seems Garage Band would have been more effective <grin>!
Old 08-30-2019, 04:49 AM
Since you won't show or look in the MIDI event list for whatever reason grab the free snoize MIDI utility. Run it outside of PT and it will show you what's going on with your MIDI setup. The sustain pedal message might not even be getting to the computer. With the exception of one or two NI instruments I've not had a sustain pedal problem.
How is the Nektar connected to the computer? USB or 5 pin DIN connector? Maybe try flipping the polarity (if you can) on your sustain pedal and see what happens.
Old 08-30-2019, 04:56 AM
Have you already ruled out the infamous MIDI Merge issue?
Old 08-31-2019, 05:21 PM
Philthy Philthy is offline
It's not infamous enough that I've ever heard of it, or that it's easy to google... what is it? I have experienced this sticky sustain pedal on recording as well, the moves are recorded correctly but not performed correctly during the recording pass... very disconcerting when trying to play
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 08-31-2019, 07:12 PM
Originally Posted by Philthy View Post
what is it?
This mode:
... sometimes acts funky.
Problems with MIDI Sustain Pedal while recording ChrisSimon Pro Tools TDM Systems (Mac) 72 06-25-2014 10:30 AM
Sustain Pedal Midi Keyboard Matt Darcy General Discussion 1 01-22-2009 07:48 AM
Problem with recording MIDI piano sustain pedal Chris7514 MIDI 5 06-11-2008 12:56 AM
Piano sustain pedal in recording Help!! Zownd Tips & Tricks 9 04-05-2004 02:21 PM
Sustain Pedal in Midi recording in PT LE Arya44 Tips & Tricks 1 11-09-2003 11:25 PM
