Old 03-30-2018, 05:19 AM
soundflows soundflows is offline
Default Eucon via VPN
Is it possible to use an Artist Mix via VPN?
I have two Routers connected via a VPN and can access all of the devices connected to either of the networks. But an Artist mix connected to one of the networks doesn't appear in the EuControl-App on a computer in the other network. Is it possible to get that working?
Old 03-30-2018, 06:22 PM
EddieJones's Avatar
Default Re: Eucon via VPN
Technically maybe... you would have to make sure ports were allowed to be opened and forwarded correctly etc. but the latency would probably cause it to drop network packets and be very buggy.
Old 03-31-2018, 03:16 AM
Do you know which ports I would have to forward? I can't find the information which ports are used in the documentation.
Old 03-31-2018, 07:28 AM
EddieJones's Avatar
The ports are not fixed unfortunately.
Old 03-31-2018, 07:31 AM
But then I can't forward them, right?!
Old 03-31-2018, 07:37 AM
EddieJones's Avatar
You have to open it up for all ports (which is probably the default anyway) Do both ends have the same subnet? I.E. what is the IP address of the workstation and what is the IP of the Surface?
Old 03-31-2018, 07:40 AM
You're right. They seem to be all open.
The way the VPN is done only allows for different subnets in the two networks.
Old 04-18-2018, 01:45 PM
Tried it on the same subnet - still not working. :/
Old 02-11-2019, 04:45 AM
willieaames willieaames is offline
Might work if you are using openvpn client such as purevpn.
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 2 07-14-2021 09:33 AM
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Avid S1, S3, Dock and Control App 0 04-18-2017 10:09 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
