Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 12-02-2014, 10:26 PM
adam79's Avatar
adam79 adam79 is offline
Default ADAT Interfaces
I've been checking out ADAT interfaces to add more channels to an interface. Can someone please explain the difference between the MOTU 896, MOTU 8pre, the Foscurite octopre LE and octopre platinum. Do all these units have the capability to connect to an interface w/ an optical in to add 8ch via ADAT light pipe (or whatever the connection is called). Or is the octopre MkII the only model w/ ADAT connectivity? I'm assuming that the mkII is the newest octopre model.
Thanks,
Adam
Old 12-03-2014, 05:52 AM
VRW VRW is offline
Default Re: ADAT Interfaces
The Focusrites are preamps/converters with ADAT OUTs only
whereas both Motus are preamps/converters and audio interfaces with ADAT OUTs and INs.
Means
the Focusrites themself can be connected to an audio interface as an mic pre extension via ADAT
but there can´t be connected any other units to the Focusrites via ADAT because of the lack of ADAT INs.
Unlike with the Motus which can be connected in standalone mode to another audio interface
working as mic pres only via ADAT...but there also can be connected other external units to the Motus via their ADAT INs.
The Motus can be used as preamps/converters only as well as complete audio interfaces.
The Focusrites only work as preamps/converters.
If you already have a decent, well working audio interface theoretically it would not make sense to buy the Motus as you
would have to pay for stuff you already have.
On the other hand if you would want to get two in one, a mic pre extension as well as a "back up"-audio interface in the
case your current one would break down once then it could make sense to get the more expensive Motus.
It´s just up to you, your needs and what you will be able to afford.
Yes, the Octopre MK2 is the newest model.
The very best to you,
VRW
ADAT interfaces for PT III PCI Keith Hernandez Digidesign Hardware & Software 0 03-18-2006 12:45 AM
Higher Sample Rates, Digi Interfaces, and ADAT Iain Graham Pro Tools TDM Systems (Mac) 5 03-03-2006 10:43 AM
ADAT Bridge 20 bit and 24 bit interfaces WestPhillySoulzition Pro Tools TDM Systems (Mac) 2 11-10-2003 12:17 PM
ad\da interfaces for 001 adat audio1420 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-23-2003 11:49 PM
HD Interfaces & 24/96 ADAT Connections fab Pro Tools TDM Systems (Mac) 1 01-18-2002 05:09 PM
