PT recognizes midi controller, will not play instrument
Pretty well stumped on this one. Using a Behringer UMX 61 controller, that I've used for years. Works fine. Will play whatever I pull up in standalone. PT sees the controller, but it will not play an instrument I pull up. Have tried several different VI's, all of which will work standalone. Last time I connected it, it was fine. Any ideas? Thanx...
"I'm not really HoboSoul, but I play him at the DUC..." Mac Pro 12Core 3.46G (5.1) | 64G Ram OSX 10.11.6 | PTHDN/OMNI/Apogee Duet(non Avid) 10.3.6 / 11.3.1 Need mixes, mastering, guitar, keyboard or bass parts added to your tracks? Need custom songs/music written and produced for special occasions? Check out The Soundz Shop. Great work by pros with multi-platinum experience at excellent prices... |
Re: PT recognizes midi controller, will not play instrument
I used to have similar midi problems with all external midi controllers (Novation Sl,Korg MS20ic,etc) any midi despite appears seem to be broke.
What worked for me was to delete the "Pro Tools" folder from user/app data/roaming/Avid/ reboot and after PT 11.0.1 restarted every midi related controller worked again. Hope this helps Cheers |
EDIT: Ahh. That's a PC thing. No? Has no one else seen this problem in OS X?
So as this mystery continues, I have switched MIDI controllers. Again, PT sees/recognizes the EMU X49 controller I've connected, but no message is received by the opened VI. Any insight appreciated...
Also you have to record enable the channel you have the VI on Hope that helps Chris
EDIT: 9/6/13- This was the answer. Thanx to those who replied...
"I'm not really HoboSoul, but I play him at the DUC..." Mac Pro 12Core 3.46G (5.1) | 64G Ram OSX 10.11.6 | PTHDN/OMNI/Apogee Duet(non Avid) 10.3.6 / 11.3.1 Need mixes, mastering, guitar, keyboard or bass parts added to your tracks? Need custom songs/music written and produced for special occasions? Check out The Soundz Shop. Great work by pros with multi-platinum experience at excellent prices... Last edited by RaySoul; 09-06-2013 at 03:14 AM. |
Make sure you right click on the VI controls or whatever modifier key you need to press for midi learn of each parameter. This probably not the problem but I'm sure you are trying anything at this point.
Dave Cournoyer-guitarist-project studio Mac Mini late 2012, i7, Sierra 16GB PT10.3.10HD PT12.5.2 Apogee Mini-Me firewire. |
MK-461C Midi Controller doing more than controlling the instrument | Rhinestone | Pro Tools 9 | 5 | 02-07-2014 11:20 AM |
RTAS Instrument Automation Writing From Midi Controller | tekk | Pro Tools 9 | 4 | 08-04-2011 10:46 AM |
How do I get a MIDI track to play an Instrument | higginsdj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 05-16-2010 04:20 AM |
MIDI and Instrument Tracks won't play back | joshuadanger | MIDI | 7 | 01-07-2010 01:47 PM |
Change Instrument Track via Midi Controller | jallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-19-2007 09:07 AM |
