Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 09-29-2013, 01:32 PM
Emcha_audio's Avatar
Default Re: 'ASIO Device has changed properties' is back with avengeance.
Originally Posted by TheJamsh View Post
Great, just when I thought we'd seen the last of this stupid glitch..
Focusrite Liquid 56, Saffire Mix Control 3.1b2. Anybody else have this issue?
Same bug I've been having when Play is loading an instrument, either inside pro tools or as a stand alone. I've called, emailed Focusrite and Play enough time that I don't remember how much by now, and nothing has ever been done.
Although this also normally happens when you open a session that is not the format the the focusrite is set to. Example if you open an old session you did in 48k while your current focusrite settings is 96k. I haven't had to create any new temple. Just save the one you tried to open, close pro tools, switch to the right sample rate/ asio settings, reopen pro tools and the session. As a good practice, write what sample rate you use as part of your session folders name.
Manny.
Wave-T.com
Old 09-29-2013, 10:10 PM
cwsand's Avatar
cwsand cwsand is offline
I had this issue a lot until I figured out that some of my overclock timing settings were wrong. Only happens now if, as said previously, you try to open a session with a different sample rate than what the interface is set to. Just make sure the sample rate is locked in to the session's sample rate in the Mix Control before booting up Pro Tools. Sometimes you might even have to power cycle the Saffire too. Not really a big issue once you figure out the correct sequence. It's also better if you tend to use one sample rate most of the time - not always possible, I know.
Would be sweet if you could change the sample rate directly in Pro Tools without having to reboot! I miss that about the 003.
Chris
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 09-29-2013, 10:40 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by cwsand View Post
I miss that about the 003. Chris
That's about the only thing I miss - my Mac is a little bit more forgiving and works generally very well - but the tight integration with my 003r and PT was very nice - low buffers also
Daniel
ASIO device properties error for a noob jon superdeath Windows 14 11-12-2017 11:50 PM
ASIO device properties have been changed by the device control panel. medinarawk Third Party Interfaces 5 07-06-2015 02:18 PM
AISO properties have been changed in the device panel YYR123 Windows 30 09-08-2013 08:01 AM
Asio device properties have been changed... guitarbin Pro Tools 10 2 03-31-2013 07:33 PM
DICE chipset+PT10="ASIO device properties have been changed by the device" Funk-O-Meter Windows 5 12-19-2012 05:12 PM
