Old 06-25-2013, 05:03 PM
fiddlecat's Avatar
fiddlecat fiddlecat is offline
Default Roland Octa-Capture crashes (PT 11 - Win 7 /64-bit )
Has anyone out there successfully run PT 11 (Win 7 / 64-bit) with a Roland Octa-Capture?
I have been running fine with PT 9 through PT 10.3.6. with this configuration. No problems at all. And in fact, PT 10.3.6 still works even after the PT 11 install, so I still have a functioning system.
However PT 11 crashes consistently. Hasn't ever worked. Sometimes the crash happens while loading libraries, etc. Sometimes I get as far as the select session screen. The crash point is not consistent. Here's the dump screen (and yes, I'll do a Sandra report if necessary):
Problem signature:
Problem Event Name: APPCRASH
Application Name: ProTools.exe
Application Version: 11.0.0.528
Application Timestamp: 51c054fd
Fault Module Name: BDM.dll
Fault Module Version: 8.0.3.0
Fault Module Timestamp: 51c0146a
Exception Code: c0000005
Exception Offset: 000000000008f9ac
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: bdc6
Additional Information 2: bdc6efdef6aab3159e9f04820019c586
Additional Information 3: c618
Additional Information 4: c61805ecba32e5aed419cbabd2a684f1
Any thoughts?
Pro Tools 2023.6 & 10.3.0
Windows 11 Professional / 64-bit
Roland Octa-Capture
Old 06-25-2013, 06:34 PM
patbensing patbensing is offline
Default Re: Roland Octa-Capture crashes (PT 11 - Win 7 /64-bit )
I am using Windows 8 64 bit, but I am getting runtime error shutdowns in different situations too with Octa Capture in PT11. Usually it won't even have Octa Capture available as an option, and will load with Full Duplex ASIO driver or Generic ASIO driver. The few times it found Octa Capture, it gave runtime errors and shutdown before I could play a project. 10.3.6 works fine as far as I have seen.
Asus P5Q Deluxe
Intel Quad CPU Q9650 3.00Ghz
8 Gigs RAM
Windows 8 Pro 64bit
Roland Octa Capture Driver Ver 1.5.1
Old 06-26-2013, 09:30 PM
fiddlecat's Avatar
OK, one more bit of information.
Just to see what would happen, I installed the drivers for my old Mbox2 tonight and Pro Tools 11 worked just fine.
So it would appear that there is some problem specifically with Pro Tools 11 interacting with the Octa-Capture drivers.
I am in contact with Roland support, so I will update if/when I find out more...
Roland Octa-Capture
Old 06-27-2013, 03:55 AM
javajunkie javajunkie is offline
I don't think I have heard one person getting the roland quad, octa, or studio capture working with 11 on Windows (not sure about Mac). We are all in the same boat here.
I also have a support call in with Roland.
Old 06-27-2013, 09:35 PM
Fir3bird Fir3bird is offline
This thread has my interest has I own an Octa-Capture but awaiting the free student upgrade to PT11.
Do you have any news?
Old 06-29-2013, 01:12 PM
Paawo Paawo is offline
Quad capture is crashing PT11 on my Win7 system also.
Working with PT 10.3.6 though.
My Saffire Pro40 works fine on both PT11 and PT10.3.6
Anyone tried the PT11.0.1 yet with Roland Quad/Octa?
Old 06-29-2013, 04:15 PM
fiddlecat's Avatar
Just gave it a try with PT 11.0.1. Same symptoms.
I guess we will need to wait for updated drivers from Roland...
Roland Octa-Capture
Old 06-30-2013, 06:45 AM
ron_from_RIFAS ron_from_RIFAS is offline
I called Steve at Roland (he's there "Recording" guy in tech support) and they're still waiting for Avid to pass along copies of Pro Tools so they can test and troubleshoot.
For my benefit he setup PT 10 with the Octa Capture and it ran without issue. I failed to ask if he'd updated the firmware and driver to 1.5 though.
In my experience with the PT11 demo the Octa Capture was a disaster. Barely any playback at all. Somethings different about PT11. With my old Fast Track Ultra you can't change the buffers without a restart which isn't an issue in PT10.
I think every interface maker is going to have to recode their drivers just for Pro Tools. We'll see how long that takes...
Start holding breath..............now.
Dell XPS 630i (ASUS P5K Deluxe Mobo)
3.0ghz Quad Core Q9650
8 Gb RAM (GSkillz)
Windows 8.1 Pro
Pro Tools 10.3.8
Focusrite 18i8, 18i20
Old 07-01-2013, 11:03 AM
social social is offline
Same here. Dosn't work. Sometimes I manage to start it, but very very buggy.
Thinking of geting a Focusrite card as people seem to have succes with it, if this isnt solved ASAP.
ASRock Pro3 / i7-2600K / Radeon 6850 / Win7 64BIT & OSX 10.7 / ProTools 11HD Native / OctaCapture
Old 07-01-2013, 10:00 PM
Bharath's Avatar
Bharath Bharath is offline
Do you know who he is in touch with? These are the kind of issues where we need help from the device manufacturer to make any kind of progress.
:: Bharath
Pro Tools Software Team
Pro Tools 9, Roland Octa Capture - iMac, No Sound Playback Mike1005 macOS 2 12-27-2013 02:59 PM
Roland Octa-Capture fiddlecat Windows 24 06-30-2013 06:35 AM
FS: Roland Octa-Capture - Like New agershon Buy & Sell 1 12-26-2012 07:51 AM
11R and Roland Octa Capture Marshall881 Eleven Rack 6 03-09-2012 08:37 PM
Roland Octa Capture mikemolloy1971 Windows 1 09-22-2011 07:23 AM
