Just upgraded from 9 to 10
Install went fine on Windows 7, however, when I go to set up and try to change buffer size, processors, or cpu usage, it will not let me change any of them. Anyone know why? Im really stumped here.
Also everytime I try to exit Pro Tools I get this error: could not complete the exit command because access violation occured, unable to read location: 0x2879616C. |
Re: Just upgraded from 9 to 10
SiSoftware Sandra
Computer Model : OEM System Product Name Workgroup : WORKGROUP Host Name : BigDaddy-PC User : Big Daddy Processor Model : Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz Speed : 3.2GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : ASUS SABERTOOTH X58 BIOS : AMI (OEM) 0505 09/03/2010 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 12GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Chipset Model : Intel Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Total Memory : 12GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 536MHz (1GHz) Memory Module(s) Memory Module : SanMax ModulePartNumber00 4GB DIMM PC17100U Memory Module : SanMax ModulePartNumber02 4GB DIMM PC17100U Memory Module : SanMax ModulePartNumber04 4GB DIMM PC17100U Video System Video Adapter : NVIDIA GeForce GTS 450 (192 SM5.0 1.65GHz, 1GB, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GTS 450 (192 SM5.0 1.65GHz, 1GB, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce GTS 450 (192SP 4C 1.65GHz, 1GB) Compute Shader Processor : NVIDIA GeForce GTS 450 (192SP 1.65GHz, 1GB) Storage Devices WDC WD1002FAEX-00Z3A0 (1TB, SATA, 3.5", 7200rpm) : 932GB (C:) SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (E:) (G:) HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA, 3.5", 7200rpm) Hard Disk (G:) : 466GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Back Up (E:) : 466GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : EVGA GF106 High Definition Audio Controller Audio Codec : nVidia 0011h Audio Codec : nVidia 0011h |
Running as administrator solved that for me.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Yea I re-did all of the optimizations this morning and it solved my hardware set up issue, but the exit error just kept on going. Remembered that I upgraded S Gear yesterday before installing PT 10. S Gear was a wrapped VST and the upgrade version was 64 bit and 32 bit. I upgraded to 64 bit by not paying attention to the instructions on the screen. That was the issue with the exit command. User error. Thanks for the response Bob, I really appreciate it. Merry Christmas!
HELP - just upgraded from 6.1.1 to 6.4 | jayp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-30-2005 04:06 PM |
Help I upgraded my Mac OS | Greyskied | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-27-2005 11:01 AM |
So I upgraded to 6.1.1.... | daede | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-20-2003 01:36 PM |
has anyone upgraded to OSX using Mix/Plus? | ssd | General Discussion | 1 | 11-16-2001 02:46 PM |
Upgraded from 9.04- > 9.1 | Frost | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-09-2001 11:56 PM |
