Old 05-15-2010, 02:38 PM
higginsdj higginsdj is offline
Default How do I get a MIDI track to play an Instrument
Another newbie question. I have a Midi track and I record on it using a midi controller (SFX triggering - not music). My instrument is a sampler (via the Ugly VSTi interface). How do I get what I recorded on the Midi Track to playback the instrument? I can monitor what I recorded but I can't play it back.
I have the midi pointed to ReWire 1. I have an instrument track that has the Ugly VSTi plugin as an insert.
I can get it working for the Mini Grand instrument but not the Sampler!
PT 8LE, OSX 10.6.3, Axiom 25
Cheers
David
Old 05-15-2010, 04:18 PM
daeron80 daeron80 is offline
Default Re: How do I get a MIDI track to play an Instrument
That looks kinda cool. So, Ugly runs as a Rewire slave? A way for Mac users to use VSTi's in PT for free. Like!
In Ugly, can you select "ReWire Bus 1" (or something similar) as the MIDI Input Device? If so, that ought to do it.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 05-15-2010, 04:19 PM
Or highlight and copy the midi data and paste it into an instrument track.
Old 05-15-2010, 06:10 PM
Apparently it is a rewire slave - I don't know much about this.
I can select ReWire 1 in Ugly and it does accept the Midi input from the recorded Midi track - but there is still no playback sound to listen to. If I try to set Ugly's output to the MBox then the ReWire settings in Pro Tools go inactive and the Midi doesn't play.
Yes, I can copy the midi into the Instrument track with the Ugly Insert but still can't hear anything in the playback....
Maybe its a bug in Ugly. I switch to the Axiom as the Midi Input device and I hear the samples. I switch to Rewire 1 and nothing. In both cases the MIDI received light in Ugly flickers so it is receiving something in both cases.
Cheers
David
Old 05-15-2010, 06:47 PM
Philly Philly is offline
Yeah i've noticed PT pretty much hogs that output channel so you cant have 2 programs running on it, had this problem with other applications anyways.
Old 05-15-2010, 07:29 PM
trondned trondned is offline
Try to create a AUX-track in PT with a rewire insert. Under "instruments" there should be something called "Ugly ReWire" or similar.
Good tip, I'll check out the Ugly myself when I'm at my PT-rig.
Good luck!
Trond Nedberg
Nedberg Audio
Kongensgate 16
0153 Oslo
Norway
Nedberg Audio
[email protected]
Old 05-15-2010, 10:40 PM
The only rewire inserts I have are Ableton Live and Ugly VSTi Interface - and I'm using the latter. Using the Ugly insert does not put any audio into the AUX track when I playback - same problem as using the Instrument track.
Cheers
David
Old 05-15-2010, 11:53 PM
flommer flommer is offline
On a lark, I decided to give this a try.
I don't have any vsti plugs, so I found a free clav modeler called Ticky Clav to have something to test.
So the process is like this:
Open UGLY, under output options, change output device to "ad_rewire"
Close Ugly
This should only need to be done once to register the Ugly VSTi to the rewire system.
Open PT, New aux track, insert the Ugly rewire client
Open ugly. MIDI input device = "Rewire 1". Load a VSTi plugin, in my case the Ticky Clav
New midi track in PT. Midi output set to "rewire 1-1"
At this point I can play/record MIDI to/from/thru the MIDI track to the clav plug, and the aux track monitors the rewire client with no problems...
Can't say what you might be doing differently. It could also be the VSTi plug you are trying to use...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 05-16-2010, 12:34 AM
The VSTi I am trying is UVIWorkstation - a freeware sampler. When you insert the Ugly rewire client, do you set the output to anything or just leave it?
Cheers
David
Old 05-16-2010, 01:48 AM
Cheers
David
No change to the rewire client
You may know this, but if you are just trying to get a basic sampler working in PT, then Structure free may do what you need, no VST funkiness required..
Instrument track doesn't play!? digidesigner Pro Tools TDM Systems (Mac) 8 02-18-2014 02:17 AM
problem play track instrument LEAR macOS 0 06-08-2011 11:00 AM
Recorded MIDI/Instrument track seen but won't play back ragbor MIDI 12 04-23-2011 09:16 AM
Having problem when i play/playback the midi instrument track yitkara MIDI 8 10-08-2010 05:11 PM
Quick fix for a instrument track that won't play ronwasserman Pro Tools TDM Systems (Mac) 4 03-31-2010 03:34 PM
