Old 02-26-2010, 06:20 AM
joji joji is offline
Default Leopard to snow leopard clean or update install
I am going to upgrade my system to snow leopard. How do you do a clean install without messing up all my plugin authorizations that are not ilok based. If I do a clean install how do i get all my preferences and plugins and protools etc working again. do i have to reinstall all my music and worprocessing software again
thanks
Old 02-26-2010, 08:49 AM
Sean Russell Sean Russell is offline
Default Re: Leopard to snow leopard clean or update install
Clean install of SL will give better PT results, with less drama.
You'll need to re-install everything fresh, and have to duke it out with companies that don't do iLok.
Yes, you'll have to reinstall your word processing apps, too.
Have a fun weekend
... but does it help the chorus?
Old 02-26-2010, 09:00 AM
D'Animation D'Animation is offline
Clean - I've just done a Leopard reinstall to fix a few things - It worth the pain, PT's 8 is now stable for me
D
Old 02-26-2010, 09:01 AM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
Clean! Originally I done the update but had lots of weird little issues. Did a clean install and everything works beautifully (knock wood.)
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 02-26-2010, 09:03 AM
Detlef Brockmann Detlef Brockmann is offline
same here: a fresh installation improved a lot of small very strange ProTools behaviers.
Old 02-26-2010, 09:13 AM
Concerttom Concerttom is offline
Clean install definitely seems to be the way to go. You can also re-import your old applications and settings toward the end of the process, if you so choose (I did it that way & it worked fine). Here's a good step-by-step blog tutorial if you need it:
http://blog.jeff-owens.com/mac-osx/s...tall-tutorial/
MacBook Pro, OS 10.6.2, Intel Core 2 Duo, 2.6 GHz, 4 GB Memory, 003 Factory, PT LE 8.0.3, G-Tech G DRIVE Q 1TB HD
'Wave of the future, Dude. One hundred percent electronic.' -- J. Treehorn
Old 02-26-2010, 09:16 AM
Pete Gates Pete Gates is offline
I'm with the clean install gang - that's what I did, but... why does it have to be so??
It's accepted wisdom to do a clean install but this isn't black magic, why can't Digi work out what isn't working with upgrade installs that works fine for every other application. Even Apple strongly guide you towards upgrade installation rather than clean installation with Snow Leopard. When I did a clean install it was about a week till I had everything back as I had on my old machine. Little utilities would suddenly be noticed by their absence, it was a total pain.
Pete
Old 02-26-2010, 09:59 AM
smfelton's Avatar
smfelton smfelton is offline
Absolutely clean install everytime. A few extra hours now against days of stress later is always a winner to me.
 OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty
Old 02-26-2010, 01:16 PM
anothercolour anothercolour is offline
I am about to do a clean install myself. I always wonder, do I need to de-authorize plugins that use the computer ID and password authorization method (such as the Toontrack products)? I have always de-authorized each one in the past; very time consuming. But I'm wondering, if, after I install the new system and the new plugins (on the same machine), if I type in the authorization codes that were given to me when I previously installed the plugins, will the software recognize that I am using the same computer and the same harddrive and, therefore, accept the original authorization codes and computer ID?
Old 01-01-2011, 01:12 PM
SplinterMathwood SplinterMathwood is offline
With a clean install of SL, can you still migrate all your other software without having to reinstall EVERYTHING (like CS4 and MS Office etc)?
That sounds like the gigantic PITA.
Thanks for this thread. One of the first to help.
If i buy a new MBP can i install snow leopard? Red Sun Studio's macOS 8 07-16-2011 04:53 PM
best way to do clean install on Snow Leopard miketeachesclass macOS 1 03-09-2011 07:14 PM
Couldn't get snow leopard install to stabilize from leopard clone update! crizdee Pro Tools TDM Systems (Mac) 2 01-11-2010 04:45 PM
Snow Leopard Install BondAudio Pro Tools TDM Systems (Mac) 1 12-22-2009 08:22 AM
Clean install ProTools LE for Snow Leopard Zoduati 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-03-2009 09:15 PM
