Snow Leopard Install
Does Snow Leopard require a complete clean install in order for PT to function correctly?
Or will the upgrade work just as well? Thanks in advance. |
Re: Snow Leopard Install
Unless you really need to go snow leopard for some specific reason or compatibility then i would stay snow free and remain on leopard. not everything is 100% yet on SL and some plugins aren't compatible yet. If you must go to SL then then a fresh install would be advised. or if you go the upgrade route then uninstall PT and re-install after the upgrade and then triple check all your plugins are up to date and compatible. Just my opinion on SL Chris
If i buy a new MBP can i install snow leopard? | Red Sun Studio's | macOS | 8 | 07-16-2011 04:53 PM |
Leopard to snow leopard clean or update install | joji | Pro Tools TDM Systems (Mac) | 10 | 01-01-2011 02:21 PM |
Mac won't read Install DVD - Snow Leopard | blizzard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-04-2010 08:32 AM |
How exactly I should install Snow Leopard? | goga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-12-2010 07:26 AM |
Couldn't get snow leopard install to stabilize from leopard clone update! | crizdee | Pro Tools TDM Systems (Mac) | 2 | 01-11-2010 04:45 PM |
