Realtime Bounce
Is this exclusive to ProTools? I have been looking at other apps such as Logic.DP and can not determine if these apps allow you to do a Realtime Bounce.
Mainly the option of being able to bounce both audio and midi aux is what I like about PT and wonder if it can be done in these others |
Re: Realtime Bounce
I dont know if logic or dp can do a realtime bounce. But I dont think DP can not sure about logic
Re: Realtime Bounce
Logic Audio´s bounce feature is realtime only, too.
Peter
http://www.merlinsound.de |
Re: Realtime Bounce
DP 3 cannot do a realtime bounce, but you can print your mix using a pair of tracks, and that sort of fakes it pretty well. You set up your routing so that all channels going to the mix sum to an internal bus. Then, create a new pair of tracks and have them listen to the mix bus you've set up. It's more convoluted than the way you'd do it in PT, but it does seem to work.
Re: Realtime Bounce
thanks for that info. can you tell me if logic will bounce midi like ProTools or how it handles this?
Thanks |
Re: Realtime Bounce
MIDI by itself cannot be bounced, only the audio signals can be, from synths that are triggered by the MIDI messages.
Z |
Re: Realtime Bounce
I'm a bit rusty in Logic since PT got midi but from what I remember the way you bounce in Logic is to bounce the outputs.
So if you have a number of tracks outputting on outs 1-2, you bounce this output pair and you'll get one stereo track. Therefore if you have an Aux/Input object that inputs the audio from your synth (triggered by your midi tracks) and outputs to outs 1-2 these will also be included. Hope this is what you meant/understandable! Pete |
Re: Realtime Bounce
Thanks again for the replies , Yes Logic does include midi in the Realtime bounce like PT.
Re: Realtime Bounce
I've always thought that Pro Tools "real time bounce" was less a feature than hindrance...it's the only thing I do like about Performer... [img]images/icons/wink.gif[/img]
Re: Realtime Bounce
It would be nice to have an optio. For ex. if you had a hunk of audio without any fades or automation and you just want to slap it to disk its feels like a waste of time bouncing it in real time.
Das [img]images/icons/rolleyes.gif[/img] |
offline bounce different than realtime bounce | grant howarth | Pro Tools 11 | 8 | 12-08-2013 09:29 PM |
Time gap after realtime bounce | philkeys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-21-2009 12:12 AM |
Realtime Bounce to disk | dave_t | Pro Tools M-Powered (Mac) | 2 | 01-13-2008 01:25 AM |
Hello, Why can't we bounce faster than realtime. | loopengine | Pro Tools TDM Systems (Mac) | 11 | 10-11-2005 07:16 PM |
Bounce to Disk vs. realtime mix | Steve Moore | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 09-16-2002 09:47 PM |
