Old 03-19-2004, 11:26 PM
Viktor Viktor is offline
Default Dr-008 questions
Hi everyone!
When opening session with 2 instance Dr-008 loaded DFH close and room kits, PT has weird behavior.
It somehow freezes,sometime -9094 message appears.Task manager shows almost 100% memory usage at this time(prosessor uses 45% though)If I increase RAM to 1MGB (currently 512) will it solve the problem?
And one more thing-I've tried choke buttons to achieve open-close hi-hat,but it doesn't seem to work.Is it just me or Dr-008 1.19 public beta has this option inactived?
Any suggestions would be greatly appreciated.
Old 03-20-2004, 10:58 AM
Default Re: Dr-008 questions
Nobody uses Dr-008?
Old 03-20-2004, 11:45 AM
mix2much mix2much is offline
I've not had the best luck using midi in protools peroid! I have yet to use the DR008 in protools though I have been using it within Sonar for a few years now and it works wonderfully in that program. As for the choke issue- For every HiHat sample, you need to select choke 1- so that they are all in the same choke group- That way they will cut each other off. Hope that solves it for ya.
Old 03-20-2004, 11:54 AM
spkguitar's Avatar
Viktor, I can't speak for DR-008, but I found when using the DFH with Kontakt and any other samples loaded that 512MB just wasn't enough memory. It would choke everything. Going to 1GB solved the problem for me.
Old 03-20-2004, 12:18 PM
Thank you much guys for responde.I'll give it a try.
Newbie questions on laptop PC selection - basic questions - thanks... half drag Windows 0 01-04-2011 01:12 PM
Crisis... I need to know it all now. Ram Questions. CPU Questions. Please......... Target Earth Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 01-04-2002 12:20 AM
Questions jeffreyr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-03-2001 09:52 AM
5.1 questions....and OSX prophei 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-29-2000 03:56 PM
Questions Questions roxy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-26-2000 07:45 AM
