RX4 Monitor authorization issue
I just upgraded my RX3 Advanced to RX4 Advanced. My understanding is that RX4 Monitor comes with the Advanced package to allow RX4 standalone to route audio through PT I/O in a similar way to DigiRewire. For some reason the RX4 Monitor plugin does not see my RX4 Advanced authorization key on my iLok and will only run in a 10 day trial mode. It says I need to go to the iZotope store and buy it but I don't even see it for sale there. All the other plugins in RX4 Advanced have correctly authorized. Has anyone experienced an issue getting RX4 Monitor to authorize? I have put in a tech support request with iZotope but wanted to see if anyone here has had any issues. I'm running PT 11.2.1 on Windows 7 - 64 bit. Thanks, David |
Re: RX4 Monitor authorization issue
I had the same problem with RX Monitor. The solution I got from Izotope tech support was to go ahead and authorize it when that window pops up. Then, uncheck the box that says to use iLock; hit submit and it should work.
Keith |
Authorization Issue Popped Up - Need Help | JCWarrior | Pro Tools 9 | 6 | 09-03-2013 08:02 AM |
ilok authorization issue | mmoeding | Pro Tools 9 | 11 | 07-27-2011 06:01 AM |
Authorization Issue | joncovey | macOS | 1 | 05-25-2011 12:12 AM |
PT 9 Authorization issue | OneMadSon | macOS | 4 | 12-28-2010 03:55 AM |
Authorization Code issue | docscholl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-07-2008 12:13 PM |
