Old 04-28-2022, 01:39 PM
Default Re: Black square dot on aux track
I'd expect maybe more folks to be complaining about these glitches instead of two (edit: five, six, seven,... mmm, maybe I'm wrong about it not being common, hah... so wrong ) if it was hitting many M1 Monterey users on 2022.4. So might be worth excluding stuff local to your computer by trying trashing prefs and then creating an entirely empty session and seeing if that problem reproduces. Then filing a support case so Avid can reproduce/get more info from you (and post the case number here).
I suspect we are going to have lots of GUI fun ahead as the Pro Tools ecosystem catches up to the latest graphics stack on Mac.
Old 04-28-2022, 03:01 PM
Burbree Burbree is offline
Me Four..
I'll do some more testing and report back
MacBook Pro Apple M1 Pro 32GB Mac OS 12.6.2 Pro Tools Ultimate 2022.12
_____________________________________________
Old 04-28-2022, 03:04 PM
zeeman zeeman is offline
I have the Black Box Also.
M1 and Monterey 12.3.1.
Everything else smooth.
z
MAC OS 13.6.1
Mac Mini M2 16gig Ram
PT 2023.12
Lynx Aurora 16n Thunderbolt
Old 04-28-2022, 03:51 PM
BScout BScout is offline
Originally Posted by zoff View Post
Me too, on Aux tracks.
Are you on an Intel / Monterey? Or M1 Monterey?
You're the only one that's chimed in on Intel so far having this problem if your signature is correct, reason I ask.
Old 04-28-2022, 04:00 PM
jeffro's Avatar
jeffro jeffro is offline
Restarted with macOS 12.3 and there it is. So... not M1 related. Logged as PT-285434.
linkedin
  #16
Old 04-28-2022, 04:45 PM
Eric Lambert's Avatar
Looks like the top-most portion of the meter is using the wide-meter graphic component while the rest of the meter is using the thin-meter graphic. I have no idea if that's the culprit, but the programmer in me has created similar bugs in the GUI. What's odd at the moment is that no one else is seeing it. Maybe try switching to wide then back to thin.
  #17
Old 04-28-2022, 05:36 PM
Dizzi45Z Dizzi45Z is offline
Originally Posted by Emi View Post
And another graphic issue,
when using takes, and change back to waveform on the track, a giant black line appears (see attached picture). It goes away when you change track hight.
I'm not seeing the black box next to the Aux Meters, but I do see this one. Big Sur 11.6. But boy am I glad to finally see VCA meters lining up correctly and much less of the big black areas.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
  #18
Old 04-29-2022, 02:00 AM
zoff zoff is offline
Yes, Intel i9 16" MBP, Monterey 12.3.1. The sig is correct.
macOS Sonoma 14.2 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2023.12, RME Babyface Pro
  #19
Old 04-29-2022, 05:32 AM
macmuse macmuse is offline
I don’t get a black box on the aux, or the black line, but I do get periodically a big square black box that looks the same except it’s a large square (sometimes two side by side a couple inches apart) up at the top of the GUI covering the marker/tempo etc. tracks. 2018 Mac mini i7, Big Sur. I’m on a 30” screen (2560x1600) and the black box is about a two-inch square. Seems like a graphic glitch, but didn’t happen in 2021.12. I’ll have to pay more attention to when it occurs.
  #20
Old 04-29-2022, 06:39 AM
Visible on both mixer widths and meter widths
Bug Video goes black when changing online track kosmokrator Post - Surround - Video 2 05-31-2021 12:58 PM
Video track in black when played back Marcomarin Pro Tools 11 5 04-24-2018 04:06 AM
There's A Surround Panner and It's Square!! alk3997 Avid S1, S3, Dock and Control App 1 05-17-2016 06:45 AM
uhh...why is my instrument track black & gold? sykobilly65 Pro Tools M-Powered (Mac) 1 08-28-2008 07:55 PM
Flakey behavior / System Resources red square? Mike Borok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-11-2007 04:25 PM
