Old 01-06-2021, 09:31 PM
frisbie9 frisbie9 is offline
Default Help lengthening section
Hi, I've been unsuccessful looking around trying to find out how to extend a section of a song. I'm trying to add a few bars to a verse section. I know how to duplicate, and i've tried the "shift" function and then dragged the section to the empty space but it's not "pushing"/lengthening the track, ie inserting without replacing.
I've spent way more time creating and trying to up my edit skills, so I'm sure this is newbie-esque question. Thank you!
Old 01-07-2021, 12:08 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Help lengthening section
Are you in Shuffle Mode?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-07-2021, 06:22 PM
No, it's been in Slip mode.
Old 01-07-2021, 06:36 PM
The Weed's Avatar
You need to be in Shuffle Mode.
If you want to copy a definite length and insert that same length at a definite spot, in Shuffle Mode, Shift+Click on Grid Mode.
Either way, in Shuffle Mode, highlight the area you want to copy, copy, put the cursor where you want to start inserting the copied audio and paste.
Slip (or Grid) will place the copied audio over whatever is there when you paste. At the insertion point, Shuffle will insert what you've copied and move everything to the right of the insertion point, to the right.
If there is something farther to the right on the Timeline you don't want moved, Lock the first Clip of what you don't want moved and that Clip and anything to the right of it will stay in place.
SonoBus
Old 01-07-2021, 06:49 PM
Awesome! Exactly what i needed....i knew it was something basic i was overlooking. Thank you so much!
Pro tools lengthening audio track conalearly macOS 0 04-01-2015 02:46 PM
How to get PT to loop a section, without having to listen to that entire section? FranHoop Pro Tools 9 3 11-04-2011 02:57 AM
RECORDING SECTION BY SECTION jayrussell Tips & Tricks 3 04-28-2008 10:59 AM
Should there be a M-Box Section BMGE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-27-2002 03:37 PM
Lengthening the cable for 001 Paver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-08-2000 07:19 AM
