Old 10-09-2008, 03:24 AM
Bart HLH Bart HLH is offline
Default unable to move warp marker
I'm working in grid mode, manually aligning warp markers to the grid. (grouped multi tracked drums)
Deleted a selection of warp markers to start over, add new warp markers, some markers drag perfectly over the grid BUT others are unmovable in grid mode! When I swap to slip mode I can drag those warp markers to the the first grid line in front of it but not further.
Trashed prefs etc... am I missing something?
Greetz,
Bart
www.highlakehill.be
Old 10-09-2008, 07:21 AM
elicious elicious is offline
Default Re: unable to move warp marker
is your grid resolution small enough?
i.e. your grid is set to 8th and your trying to move it an 8th where a marker already sits.
b.o.l.
e
ihatetyping
Old 10-09-2008, 07:58 AM
yep, tried every grid resolution but no movement...
The strange part is that in slip mode I can only move the marker to the grid line in front of it, not further.
www.highlakehill.be
Old 10-09-2008, 08:11 AM
rdolmat rdolmat is offline
yeah...I get that once in a while too....not sure why. Only when editing multitracks (ie: drums)...
mayhap it's fixed in PT 8?
cheers,
rich
Does ELASTIC AUDIO always leave artifacts on every warp marker P,B,S Pro Tools 10 5 01-23-2013 11:15 AM
Easy way to add warp marker to region boundary? EricWillhelm Pro Tools 9 1 12-09-2010 06:25 AM
Play start marker won't move Badertime@hotmail.com 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-25-2010 02:24 PM
Warp Marker Problem shultzee13 Pro Tools M-Powered (Mac) 0 02-07-2010 09:27 AM
Automatic warp marker placement without quantizing? FreqSabotage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2009 03:58 AM
