#41
Re: Need Some New Mac Pro Advice
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
#42
Carl
If I was in your place I'd focus on fixing the computer you have. Taking forever to boot is quite likely a software problem, not hardware. Hardware problems that might cause that are when a whole memory DIMM or bank of DIMMS fails and the computer tries to boot on a tiny amount of memory. Once it is booted check the System Information report, save that elsewhere/print it out for reference. Check the system console logs (Console.app) for errors and warnings. Try a SMC reset. Do you have a series of bootable backups/clones of your boot drive? Like you probably should be making with Carbon Copy Cloner--if so can you go back to on older one of those and see how it boots? if not then do an clean full OS X install on a new drive (ideally a SSD, like a Samsung 850 Pro). Either internally or in an external USB dock (sure that drive will only run at slow USB 2 speeds on a Cheesegrater unless you have added a USB 3 PCIe card... but it should never take hours.) and just install a full new clean OS X on it, nothing else, and see if that boot and runs OK. If so then I'd get that drive installed internally and start installing Pro Tools an any really require drivers etc. Making Carbon Copy cloner backups as you go. Do not use systems migration assistant. Reinstall everything from scratch. If you don't have time to do that take the Mac to a repair shop and ask them to install a new drive and clean copy of OS X on that drive. They can run diags on it for you and blow out dust etc. while there. Failing that, if there is actually a problem with your Mac Pro then I would just buy a used Cheesegrater. Some places will take your faulty model as a trade. Upgrade the new one if necessary. I just would not buy an now-old Trashcan that is likely to be replaced with new packaging in ~1 year. Especially because you rely on PCIe cards. And *hopefully* the new Mac Pro will have PCIe slots, so investing in external card cages might be a waste of time. |
#43
Steve Shepherd Extreme Mixing |
#44
Well there is no doubt on the later. It will have be USB-C (USB 3.1, Thunderbolt 3, and display). There is no way Apple could ship a new generation Pro product without that. As for other stuff I have no idea. But I certainly hope they provide multiple internal M.2 like SSD slots, I just hope they are really M.2 slots able to take third party drives. As for standard PCIe expansion slots, I sure would hope they do. And that is not far fetched. The driving force for new high-end Pro boxes is very likely AR/VR and video work. They complaints around the gutless GPUs in the trashcans and AR/VR futures seem pretty tied to the recent announcement of that. Given the rate of GPU technology growth it makes no sense at all to not support more industry standard GPU cards in standard PCIe slots. And once you do that you might as well drop in a few more slots. The mess that Apple has gotten themselves in with thunderbolt and their insistance on display support over thunderbolt make it a bit more complex to support GPU display cards. But that was their own doing, and they need to sort it out. The only Mac Pro I'll ever buy again will have PCIe slots and support for modern NVIDIA GPUs.. but that's for reasons not related to audio. |
#45
I purchased a used 12 core tower from macsales. Will keep me going hopefully until Apple comes out with the next gen mac pro.
Thanks for all your advice. Very much appreciated. Carl
#46
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
#47
Happily up and running. Thanks for all the support.
C
#48
Carl,
happy it worked out... What macOS are you running and does it still appear fast on the older machines. I am betting yes.. But don't have the actual experienced to back up my thoughts. Thx...
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
#49
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. Last edited by Carl Lie; 05-07-2017 at 08:26 AM. |
#50
right now i am running everything SSD .. System, Audio, Samples on 4 drives .. if Apple Borks this attempt at a new MAcPro - or you cannot wait until some time in 2018 .. this might be the best way to stay current without a Trashcan / External Everything scenario ..
I need an advice from you please :) | Becharax | General Discussion | 72 | 03-19-2013 09:21 AM |
Advice for LE / HD | Kudy | Pro Tools TDM Systems (Win) | 3 | 05-01-2007 11:05 PM |
Need Advice | abre | Pro Tools M-Powered (Win) | 1 | 04-15-2007 07:13 AM |
Advice Please | planetpea | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-31-2002 08:22 PM |
NEED ADVICE! | patrickb | Pro Tools TDM Systems (Mac) | 0 | 06-05-2000 08:05 AM |
