Pro Tools and Reason not recognising Midi
Can someone please help me with my dilemma?
I am using Pro Tools LE version 8.0 with an MBox 2 and Roland FP3 on PC. When I upgraded to version 8.0 at the start of the year, Reason would no longer work. I had to input the registration details in order for it to work again (these I could not find), but I later found them when I moved house. I re-registered Reason and it was then available to use. But since then, Pro Tools and Reason do not recognise my midi cable. I've checked it's all connected and tried under various menus to find the problem. Can somebody please suggest what may be the problem? Thank you |
Re: Pro Tools and Reason not recognising Midi
For starters, make sure the midi cables are all the way in. This has happened to me. If you have an extra cable try that one too. Cables go bad every now and then, so I hear.
Thanks for your reply. I bought a new lead but no luck. I've pushed them in as far as possible but it doesn't seem to work either way.
Would you recommend reinstalling ProTools and Reason? |
Have you tried going into the midi setup to make sure nothing has changed?
Pro Tools 10 not recognising outboard | RoxyRiot | Pro Tools 10 | 1 | 02-14-2014 05:45 AM |
PT not recognising MIDI velocity changes? | DFN | macOS | 6 | 01-20-2012 07:09 PM |
Not Recognising Digi 002 in Audio Midi Setup | Calum M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-20-2009 11:20 AM |
Pro Tools is not recognising my 002 | macanudo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-18-2006 06:23 AM |
Protools 6.0.1 Update - Digi 001 Not recognising MIDI! | Mety | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-04-2003 03:23 PM |
