Old 06-20-2012, 11:21 PM
Blake Henderson Blake Henderson is offline
Default Hackintosh PCI-X Core Card problem
Hi folks. I know that some of you aren't interested in doing tech support for your fellow pro-toolers who are going the hackintosh route. But I also know that many of you run i7 builds without any problems. I am hoping that someone has some insight into my issue.
I've had a very stable Hackintosh system for over a year now. I've recently tried to install a digidesign HD pci-x card into my Gigabyte X58a-ud3r (rev. 2 FF) MB and the OS recognizes it perfectly. I can even play all system audio through it without problems. But my Pro Tools software does not "see" it as a "current engine" option, despite having a proper PT HD9 licence on my ilok.
I wonder if anyone else using PT has had a similar problem. When Pro tools boots up, it connects to my Apogee symphony which clicks, but once PT opens I don't have the HD option in the playback engine pulldown.
I can access my Symphony via the core card simply by running Core audio, wherein I have total control over the Symphony setting (CoreAudio thinks its an HD io).
thanks
blake
Clumsy Congregation
Old 06-21-2012, 12:41 PM
Default Re: Hackintosh PCI-X Core Card problem
Its a bit frustrating, given that the card is recognized without fail by Logic Pro and works well in that app. It seems that somehow PT is just not registering the core card's existence during startup.
none of you folks have experienced this?
blake
Clumsy Congregation
Old 06-21-2012, 01:12 PM
Brandonx1 Brandonx1 is offline
FYI You need the Pro Tools 9 and Pro Tools 9 HD authorization on your ilok to run PT HD.
Best
Old 06-21-2012, 02:33 PM
Hi Brandon.
I have both.
This problem relates to to complexities of using my hackintosh, I presume, not to any obvious user error. My Ilok has both licenses on it.
thanks though.
Blake
Clumsy Congregation
Old 06-23-2012, 08:06 AM
cdavis6406 cdavis6406 is offline
Make sure your in a 16x slot not a 4x. Dont know the board, but on my hackintosh it makes a difference. It will work in slower slot for system sound but not PTLS.
Just a thought. Good luck.
Mac Pro, Snow PT 10HD,Sequoia, Reaper
W7/64, PT 9HD,Sequoia, Reaper
192 HD, HD-N, 002C BLA,
BLA AGB,Autuer,Lucid,
MicroCLock, Pultec, UA, Sebatron, Focusrite, Trident,API, A-Designs, Purple Audio
Old 06-25-2012, 11:05 AM
DAvis,
My card is PCI-X and I only have one PCI slot. It won't go into any of the PCI-e slots, regardless of bus speed.
Any other tips, folks?!
Clumsy Congregation
Old 06-25-2012, 11:36 AM
Dism Dism is offline
Originally Posted by Blake Henderson View Post
DAvis,
When in doubt... maybe a fresh OS install is in order?
I highly doubt it's the PCI slot, since you say it works fine in other apps. I'd give Pro Tools a clean reinstall, including the HD drivers... and if that doesn't work, start again with a new OSX install.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 06-25-2012, 12:41 PM
thanks Dism. This was a brand new, clean, install. Ill try another though.
blake
Clumsy Congregation
Old 06-29-2012, 02:07 PM
YYR123's Avatar
YYR123 YYR123 is offline
as i posted on your other thread......does digitest pass the card?
Daniel
6-core gaming hackintosh sale or trade for 27" imac mesa3077boogie Buy & Sell 2 12-08-2013 01:13 PM
weird problem with core card DHG MUSIC macOS 8 03-16-2013 02:35 PM
Hackintosh Problem pocketcalc macOS 2 07-08-2012 05:35 PM
hackintosh / win 7 graphics card stgaudio Pro Tools 10 14 03-06-2012 04:00 AM
Need opinions: Do I have Core card problem or computer problem? johnnyv Pro Tools TDM Systems (Mac) 2 08-11-2010 06:36 PM
