Re: Protools 10 with Harpertown (early 2008) Mac Pro?
Given the limitations of ram address, ever thought of trying to run PT10 64bit?
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
10.6.8 isn't 64bit?
Nope, it's a 32 bit kernel
I believe they went x64 with 10.8 if not 10.7
I found this info in apple support: https://support.apple.com/en-us/HT3770 These Macs use the 64-bit kernel by default in Mac OS X Server v10.6 (they can also use the 64-bit kernel in Mac OS X v10.6, but do not use it by default).
My Mac Pro says it's a MacBOOK Pro! It always did. Attachment 6037 Anyone seen this before? I don't think I'm going to change anything. As long as it works... |
we cannot see your attachment .. or at least i cannot .. attachment 6037 .. weird !
#16
I always found it troublesome to attatch graphics here. This time I tried to use the function represented by a paperclip. If I try to just drag and drop a simple partial screenshot here, I get the error: "The text that you have entered is too long (44191 characters). Please shorten it to 30000 characters long." I put it on Dropbox: https://www.dropbox.com/s/xhohp8vaq3...00.49.png?dl=0 |
#17
Had enough of windows and pro tools. So im entering the Mac world i know nothing about what operating systems they use etc. Ive just brough a PE6r4 to use with a mac pro that im looking to buy of ebay this is the one im looking at https://www.ebay.co.uk/i/202075464831
will this run Pro Tools 10HD ok or will i have issues. I think i need it to have snow leopard installed as the OSX. Hopefully someone here can advise me. Thank you in advance
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
#18
Yes it will work.
Less Native power than a 2010 or 2012 but it will work. I had that same machine and for the time it was great, worked great. Ran HD with it, HD9 iirc. I personally would ask them to put 10.8.5 Mountain Lion on the Install. 10.6.8 would be just fine but 10.8.5 is a new and imho better quicker faster OS. I mean just the fact that you can resize finder windows on all corners is so much worth it. SSD support in 10.8.5, I am not sure how 10.6.8 handles SSD’s. I would also upgrade the GPU to avoid issues with graphics
#19
So is that not the standard graphics card ??? Someone in another thread said the ram bus was slow. 99% of the plugins I use are TDM. I just want my system to be stable and reliable. This is what my PC system lacks and infront of clients that’s not good Sent from my iPhone using Tapatalk
Raoul Crane
#20
Sure the Ram bus is slow....compared to todays standard even the 2012's were slow...and those are really great machines. In short the 2008 is a good system, but your money will last longer if you upgrade to a 2010/2012 Mac Pro. If you can't that's cool too, as long as it boots up i am sure PT 10 will work like a charm. The first mac I got was that 2008 8-Core system...I had come from a PC as well....and man I was blown away. I didn't turn that system off for months....I just let it sleep when I wasn't using it.....and PT Ran like a dream. Not one hiccup.
PT 11 & early 2008 Mac Pro 3,1 | IslandStylee04 | Pro Tools 11 | 56 | 07-31-2014 04:22 PM |
Anybody successfully running a HDX2 on a Mac Pro 8-core Early 2008 Harpertown? | Eduardo Apolonia | Pro Tools HDX & HD Native Systems (Mac) | 7 | 11-23-2012 12:58 AM |
HDX on early 2008 Mac Pro 8 Core.... no go ? :-( | Zownd | Pro Tools HDX & HD Native Systems (Mac) | 8 | 12-27-2011 04:04 PM |
Early 2008 Mac Pro w/HD Native? | DJ FADE | Pro Tools HDX & HD Native Systems (Mac) | 13 | 11-01-2011 05:51 PM |
Will 2008 Quad Core Harpertown Mac Pro work with HDX card ? | karljohnson | macOS | 16 | 10-25-2011 12:33 PM |
