Lacie Rugged Hard Drive
hi, is anyone using the Lacie Rugged Hard Drive 500GB FW800+400 7200 RPM for playback and record with L.E. and H.D. 8.0 and up? I am trying to find out if it uses the Oxford 911/912/924 chipset interface, as required by P.T.
Otherwise, can anyone recommend an external hard drive that is 500GB or more, small and doesn't require an external power supply (bus powered)?? I mean, one that will playback and record on LE and HD 8.0 and up? I am using macs 10.5.8 thanks!
I am using: Macbook Pro 10.5.8 Processor: 2.4 GHz Intel Core 2 Duo Memory: 4 GB 667 MHz DDR2 SDRAM M-Box 2 Mini ProTools LE 8.0.3 |
Re: Lacie Rugged Hard Drive
OWC has some very nice 2.5" firewire drives and you can get them with a 7200 rpm drive installed, which should be perfect for what you need. Check this one http://eshop.macsales.com/item/Other.../MS4U7500GB16/
I've had 4 LaCie external hard drives and ALL of them have eventually overheated and crashed my drives... I bought 3 inititally a long time ago, then decided to give them one more shot on the last one, but no more LaCie for me... They aren't ventilated well and I am guessing the metal enclosure doesn't help matters... I don't know if the one you are looking at has a metal enclosure, but I've not had good luck with this brand.
http://www.youtube.com/user/vaisatchatrucci |
I've never heard of OWC before... it is tempting because they cost half the price of Lacie, but are they reliable?
Probably the most popular FW drive on the DUC.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
LaCie Rugged USB 3.0 SSD 120 | CalebB | macOS | 6 | 05-28-2013 02:38 PM |
Mbox2Pro through LaCie Rugged Triple | Martimeus | FireWire & USB Audio Interfaces (Mac) | 14 | 04-26-2013 02:53 PM |
Unable to work on Protools LE 8 with attached LaCie Rugged Safe Portable Drive | ashishv_26 | Storage Subsystems | 6 | 02-23-2012 10:44 AM |
Disk Enclosure or Lacie Rugged style drive? | MorganIR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-02-2010 07:32 PM |
lacie rugged drive for stereo recordings | drguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-13-2008 10:40 PM |
