Behringer BCF-2000 USB/MIDI Controller HELP?
I recently purchased the Mbox and a Behringer BCF-2000 USB/MIDI controller surface. I cannot get this thing to work. Do any of you have the Behringer controller? I've been told that I could use the MAckie HUI settings to run it... but it's a Behringer unit, so I don't know. I installed the MIDI drivers and everything. When I go into SETUPS > PERIPHERALS > MIDI CONTROLLERS... I select HUI for #1 in the list, then I set the recieve and send to the BCF Unit. But after closing the setup window, I still get "ProTools is unable to communicate with HUI". Where do I start? What am I missing? (I am running ProTools LE 6.1.1 on a WinXP system) Thank you, Jesse |
question regarding Behringer midi controller & Digidesign Protools compatibility | impolding | MIDI | 1 | 09-11-2008 01:37 AM |
Pro tools v.7 + Behringer BCR-2000 midi controller | themann | MIDI | 4 | 02-09-2006 02:42 AM |
Behringer BCF-2000 USB/MIDI controller HELP? | afxsguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-25-2004 04:30 PM |
MPC 2000 as a MIDI controller in OS9 with Mach5? | Sunking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-12-2003 01:26 AM |
MPC 2000 as a MIDI controller in OS9 with Mach5? | Sunking | Pro Tools TDM Systems (Mac) | 0 | 12-12-2003 01:17 AM |
