Purchase new mainboard?
Can someome from Tech Support please advise whether I can purchase a new Mainboard for 11r direct from AVID and quote me via PM? I have tried to send an email through the AVID website but to no avail. Just recently my 11rack went from hero to zero and is stuck on the boot screen. I have tried all the available fixes but its a brick. Although it is 3 years old it has had barely 12 months use because of my work roster. Upon opening the unit i discovered that: a) the 2 led's near the DSP chips actually have a red and a green side in the one chip and both led's are static. Is this normal? b) the green led near the SW2 button in the middle of the board is flashing green. Normal. c) my technical expertise is zero so i put the lid back on. My ARC quoted $165 AU to diagnose the issue and up to $500 AU to repair depending on the problem. Plus postage which would be $140 AU for a round trip. So minimum just for diagnosis is $305 AU. My 11 is my only ' dongle' for protools and i cant afford to lay out the cost of a new 11 and was hoping a new board would be somewhere in the middle road. (Bear in mind a new 11R in australia retails for $800 - 900) I have had this board repaired previously for the clock issue which swapped the problem of 44.1 & 88.2k not working to 48 & 96k. I dont care about this because most of my work is done at 44.1. Thanks in advance for any info
Eleven Rack + ERXP Pro Tools 9 Windows 7 Gibson Guitars Washburn Guitars Michael Kelly Guitars Yamaha Bass Roland TD30K EZ Drummer 2 Superior Drummer 2.2 |
Re: Purchase new mainboard?
Have you tried calling tech support and asking?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Yeah I have. Unfortunately I get the dreaded 'the number you called is disconnected' message
I've asked that someone from Avid take a look at this, whether or not they will, I don't know.
Thanks Benoni. Much appreciated
Gee whiz, I thought this would be a simple yes or no question.
It might be best to try calling again or sending an email, or maybe contact who you bought it from and see if they can get in contact with someone who would know the details.
http://www.avid.com/US/products/elev...antyrepairInfo
I don't know the answer to the board question but knowing the service parts often have silly prices and normally need to be obtained through a Authorized Repair Center anyway I would look hard at buying buying a new unit of of eBay and selling the old one for parts. Last I knew you could get a new unregistered 11R rack minus software for >400.00 USD. Since its new it should have a warranty. A new board probably wouldn't if your servicing it yourself.
I can't imagine that the retail on the main board as a service part is any less than 300.00 and likely more. That's a hunch or guess however. I have no information on the actual cost. It could be 199.00 but I doubt it.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
http://www.ebay.com/itm/AVID-ELEVEN-...item1e8002c668
For 377 free shipping, this one comes with registration card, so you get the warranty also as you should be able to register it. No pro tools. |
Heck EJ is selling one for $360 in the but and sell section free shIp
Abit KV8 Max 3 mainboard compatibility?? | Rowan C | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-07-2004 03:38 PM |
OT: tubes on mainboard... | b@RT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-19-2002 03:02 AM |
K7T Pro-R Mainboard and Digi 001 | mgermani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 09-08-2001 08:35 AM |
New Mainboard | tjkili | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-23-2000 12:54 AM |
Mainboard Asus K7M?? | tjkili | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-12-2000 03:11 PM |
