Old 08-20-2011, 11:40 PM
giltzer14 giltzer14 is offline
Default Mbox 3 Pro External Headphone Amplifier Issue
I use an Mbox 3 Pro and have it sending stereo feed (Outputs 3-4) to a headphone amplifier so more than 2 of us can monitor our mix with individual volumes. This has worked great so far because through the Mbox Control panel I am able to send the main mix through my normal monitors (Outputs 1-2) as well as the headphone amplifier(outputs 3-4).
My problem is that when we are listening to the mix through headphones, we do not want the monitors playing. the main control knob on the Mbox 3 Pro controls the speaker outputs. I am unable to send sound to the headphone amplifier when the volume is turned down. The 2 headphone jacks on the Mbox 3 pro work independently of the main volume knob, however I'd like to utilize my headphone amplifier for additional headphones/cues.
Any ideas? As of right now the only way i can make this work is by physically unplugging my monitors from the mbox, but that is not an ideal solution by any means.
Old 08-21-2011, 06:23 AM
formfunction formfunction is offline
Default Re: Mbox 3 Pro External Headphone Amplifier Issue
Originally Posted by giltzer14 View Post
Put one of these between your M-Box and your monitors..
http://www.tcelectronic.com/levelpilot.asp ff
Old 08-21-2011, 02:39 PM
Hmm...that looks pretty cool. I'm confused how that will help my situation though. I need some way, either hardware or software, that gives me a stereo send besides Out 1-2 and the 2 headphone jacks that is independent of the master volume knob. That device seems to give another place to control volume, but it will still rely on the mbox for initial volume control....
Old 08-22-2011, 03:56 AM
manichouse manichouse is offline
got to setup / output setup and make sure that "master volume" is not checked for the outputs that you want to use to drive your external headphone amp.
Martin Trum
Old 08-23-2011, 01:03 PM
@manichouse - That did the trick! Thanks so much.
Old 08-23-2011, 02:46 PM
glad you got it sorted
Martin Trum
[IMG] code is Off
Aphex Headpod 454 Headphone Amplifier TVPostSound Buy & Sell 3 03-07-2013 11:51 AM
Headphone issue with mbox 2 / pro tools 8.... cantnot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-10-2009 03:48 PM
002R Headphone Amplifier Impedance onlyone-jc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-25-2007 09:42 AM
Need help with a Mackie headphone amplifier. ( Hook up ) Elton Hyland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-02-2007 05:26 PM
How do I connect my headphone amplifier to my 96i/o? Reverend Dan Tips & Tricks 3 09-23-2002 12:40 AM
