Old 04-30-2005, 11:49 PM
Joe Evans Joe Evans is offline
Default Search function
Anyone else having the search function on the DUC acting a little flakey lately? No matter what terms I use for the search engine, it always pulls up the most current posts on the particular group I am searching. Nothing about what I actually searched for.....
--joe
Old 05-01-2005, 12:19 AM
Brain Digger Brain Digger is offline
Default Re: Search function
I have noticed this for about two months now--on and off--more off than on really.
Anyone know what is up? DIGI?
XP Pro SP2
PTLE 7.4cs2-002R
Intel Core 2 Quad 2.4 GHz
K8V-SE Deluxe 4G DDR400
Radeon 9200SE-128M
Maxt 80G; WD 200G
CG8 200G SATA
Old 05-01-2005, 01:18 AM
Avid's Avatar
Avid Avid is offline
Administrator
Seems the same to me, but I don't know what your search criteria is.
Try it like this and see if it helps narrow the search:
+word +word
Also, we added a Google search to the DUC header that searches anything on the digidesign.com domain, including duc.digidesign.com. Click on that and put your search in at the top, see if that works for you.
Otherwise, maybe you could give me an example of a search that does not seem to be working and I can look at the specifics.
Administrator
Old 05-01-2005, 05:35 AM
Seems that I was leaving out the "+" before the search terms and that caused the weirdness. I tried it with the "+" and all is well with the world again. Thanks Digi! I guess I should have read the instructions.....
--joe
Problems with search function in ver 1.1 billunatic Avid Scorch (iOS) Forum 4 01-05-2012 11:45 AM
is the search function not working????????? gwattaloopy1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-23-2006 11:36 AM
What's the trick to using the SEARCH function ? bH101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-07-2004 01:27 AM
MIDI Search and Replace Function? altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-30-2004 01:08 PM
What's up with the DUC search function? Amerihudge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-25-2003 02:01 AM
