Old 02-10-2021, 11:07 PM
roundbadge roundbadge is offline
Default plug ins and fader windows randomly collapse PT 2020.12 & S!'s
Hi guys.running a brand new Mac Pro 7.1 with all current PT [2020.12] HDX eucontrol [2020.11.1]and 2 new S1's,one of which I replaced because of these problems..
plug ins constantly collapse when opened.super annoying
fader windows constantly pop up unprompted and won't collapse when I try.
the work around for plug ins is hit shift at launch..its a mess and making my work impossible
any ideas?
everything is 4 months old.. basically brand new
Old 02-11-2021, 06:35 AM
reichman's Avatar
reichman reichman is offline
Default Re: plug ins and fader windows randomly collapse PT 2020.12 & S!'s
The EuCon Settings windows have a lot of features and preference settings. You can control the way the surface changes your GUI and vice-versa. Check out the menu named "Open Windows on Workstation When Editing:"
Good luck!
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 02-11-2021, 09:16 AM
EddieJones's Avatar
We have added a lot more control and flexibility to accommodate different workflows over the past couple of years. Unfortunately, it makes initial setup more complicated. Take a look at the General Settings help on page 94 on, for help in setting this all up. If you still have questions don't hesitate to post them here.
EuControl Guide
Old 02-12-2021, 10:06 PM
ok so is there a specific place in the guide that addresses my plug ins constantly collapsing?
I'm not adjusting plug ins on the S1's.this is an issue with my plug in windows randomly collapsing and random aux fades main fader windows ping up all the time..those won't collapse when I try to.they keep popping back up...all on my main computer screen.
the only fix is hitting shift when opening them or completely unplugging the S1's.which is a basic workflow nightmare when working fast.
I'll keep looking and experimenting but this is getting painful .in the middle of a job.
thank you guys for the responses!
Old 02-13-2021, 10:44 AM
EddieJones's Avatar
See my response above, specifically the Open Windows and the Close Window settings
Old 02-14-2021, 10:07 AM
So just fwiw; occasionally on my rig; I'll have a plugin open, I'll then click on a track in the edit window and the plugin window will close. All Eucon prefs are set to *not* open or close anything on selecting tracks. It happens intermittently (like 4 or 5 times a day) so, often enough to be an annoyance, but not often enough to be able to track it down. This is new behavior since going Eucon.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-14-2021, 11:52 PM
Guys I've played with every single mode in the preferences menu of EuControl .
its still happening totally randomly and really starting to drive me nuts.
no rhyme or reason.plug ins still randomly collapse and random fader windows pop up and won't collapse.
this happens more often than not.
Ive already replaced one brand new unit from vintage King in hopes it would fix this.
I'm literally at the point of dumping both S1's for good.
Old 02-14-2021, 11:56 PM
de select everything it still happens
Old 02-16-2021, 11:07 PM
Still no luck.tried switch order of S1's different track ball different mouse etc.
please help before I throw these S1's into the classifieds.
Old 02-17-2021, 01:21 AM
cosmotone cosmotone is offline
Try setting "Open Window on Workstation When Editing" to Off ?
bug - 2020.9.1 completely crashes randomly when sliding audio clips zachxweeks Pro Tools 2020 0 10-20-2020 10:16 AM
Mbox 3 Pro on Windows 8 randomly going mute ddj1991 FireWire & USB Audio Interfaces (Win) 15 07-28-2016 04:52 AM
Pro Tools 9 randomly freezes my system. Windows 7 shimmyshimmy Windows 9 09-20-2011 11:45 AM
003 fader randomly stops working. GloryIsSilent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-16-2010 12:33 PM
Windows XP Hangs Randomly Riad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-08-2003 05:33 AM
