PC bogs down to a crawl and only get static as playback..
So i ran pro tools mp with my fast track pro on my acer (quad core, 6gb, win7 64-bit) and had a minimal slow down on my computer. But I recently upgraded my rig
-ASRock Fatal1ty 990FX Killer AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard -AMD FX-6300 Vishera 6-Core 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Desktop Processor -G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL10D-16GBXL -Windows 7 64-bit And now, after installing pro tools, it bogs down my PC to the point it takes 20-25 seconds for even the play button to work.. and when it does, the playback has static with a 3 second pause in between. HALP! |
Re: PC bogs down to a crawl and only get static as playback..
Thought by now somebody would have replied Post a full Sandra report as described here:
Help us Help You - READ THIS Before Posting! At the moment, I am worried that this motherboard may not have a compatible chipset. AMD builds are a bit of a crapshoot these days. While they were "the shizzle" back in the days of XP and LE8, these days, the intel i7 builds have left the AMD stuff in the dust(but even those can all to often, use a chipset that doesn't agree with Pro Tools). The safest chipsets for intel seem to be X58, X79 and Z99(with a few others I can't recall). As for AMD builds and chipsets, I am out of the loop(but the Sandra report will help the AMD users to offer better advice). Also, are you using the M-Audio ASIO driver, or ASIO4ALL? BTW, if you really need it, I can dig out my 003 and fire it up to see the firmware version. Just send me a PM and give me a day or so to get to it
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix BTW, my name is Dave, but most people call me.........................Dave Last edited by albee1952; 02-24-2015 at 09:36 PM. |
Thanks for the heads up!, heres my sandra report..
SiSoftware Sandra ID Host Name : Owner-PC Workgroup : WORKGROUP Computer Model : OEM Serial Number : To Be Fille*********** Chassis : Desktop Mainboard : ASRock 990FX Killer Serial Number : M80-4A0******** BIOS : AMI (OEM) P1.30 10/14/2014 Total Memory : 8GB DIMM DDR3 Processors Processor : AMD FX(tm)-6300 Six-Core Processor (3M 6T 4.09GHz, 2GHz IMC, 3x 2MB L2, 2x 8MB L3) Socket/Slot : AM2r2/AM3 Chipset Memory Controller : AMD F15 (Orochi) CPU HT Hub 2x 1.3GHz (2.6GHz), 2x 4GB DIMM DDR3 1.6GHz 128-bit Memory Module(s) Memory Module : G.Skill F3-2133C9-4GXL 4GB DIMM DDR3 PC3-17100U DDR3-2134 (11-11-11-29 5-40-13-6) Memory Module : G.Skill F3-2133C9-4GXL 4GB DIMM DDR3 PC3-17100U DDR3-2134 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : SANYO LCD (1600x1200, 29.8") Video Adapter : AMD Radeon R9 200 Series (44CU 2816SP SM5.0 1GHz, 4GB DDR5 5GHz 512-bit, PCIe 3.00 x16) Graphics Processor OpenCL GP Processor : AMD Radeon R9 200 Series (2816SP 44C 1GHz, 3GB DDR5 5GHz 512-bit) Compute Shader Processor : AMD Radeon R9 200 Series (2816SP 44C 1GHz, 4GB DDR5 5GHz 512-bit) Storage Devices Western Digital WDC WD10EADS-00M2B0 (1TB, SATA300, 3.5", 32MB Cache) : 932GB (C:) HL-DT-ST DVDRAM GH41N (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices System Reserved : 100MB (NTFS) Hard Disk (C:) : 931GB (NTFS) @ Western Digital WDC WD10EADS-00M2B0 (1TB, SATA300, 3.5", 32MB Cache) Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GH41N (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASRock IXP SB600/700/800 SMBUS Controller LPC Hub Controller 2 : ASRock SB700/800 LPC host controller Audio Device : ASRock IXP SB600 High Definition Audio Controller Audio Codec : Realtek Semi 0900 Audio Codec : 32768 0000 Audio Device : MSI High Definition Audio Controller Audio Codec : ATI (AMD) HDMI Audio Serial Port(s) : 1 Disk Controller : ASRock SB700/800 SATA Controller [AHCI mode] Disk Controller : ASRock SB700/800 IDE USB Controller 1 : ASRock SB700/800 USB OHCI0 Controller USB Controller 2 : ASRock SB700/800 USB EHCI Controller USB Controller 3 : ASRock SB700/800 USB OHCI0 Controller USB Controller 4 : ASRock SB700/800 USB EHCI Controller USB Controller 5 : ASRock SB700/800 USB OHCI2 Controller USB Controller 6 : ASRock SB700/800 USB OHCI0 Controller USB Controller 7 : ASRock SB700/800 USB EHCI Controller USB Controller 8 : ASRock EJ188/EJ198 USB 3.0 Host Controller SMBus/i2c Controller 1 : ATI SB800 SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : HP Officejet 5600 series (600x600, USB, Colour) Network Services Network Adapter : Killer e2200 PCI-E Gigabit Ethernet Controller (NDIS 6.20) (Ethernet, 1Gbps) Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
I'm not up on ADM chipset compatibility, but I'd just never use a PC for Pro Tools that was not an i7 or E5 Xeon.
But.... you only show one disk drive, presumably you are trying to record audio to that, not a good idea. I'm not sure what M-Powered official minimum systems requirements are but for normal Pro Tools you are supposed to have a separate hard drive dedicated for just audio/session files, and it needs to be at least 7,200 RPM. But it gets (much) worse. The drive that it looks like you are sharing between the boot/system and audio/session is a WD Caviar Green drive, a drive that is certainly not 7,200 RPM, but more specifically its aggressive "green" power management tracks are absolutely toxic to pro Tools. If it ever worked for you, you would have been lucky. Is this the cause of your problem? We have not idea at all, but one of our first steps to troubleshooting this should be to get a proper spec dedicated audio/session drive. Ideally a nice good quality SATA III SDD like a Samsung 850 Evo, or if you go for a spinning HDD then a WDC Black (*not* the Black2 combo HDD/SSD drive) and install internally connected to a SATA III port. If going with a Samsung SSD, install their Magician software, and let me know and I'll give you soem config tips. Get teh largest 850 Evo you can can afford, and certainly avoid the smallest ones (for overall value/usefulness and for wear life reasons). Oh and I'd get another SSD (or fast HDD) and replace that Caviar Green drive as the boot/system drive. They really are awful, slow drives. --- What exact version of Pro Tools MP are you using? Do you have any third party plugins installed? What interface and driver version are you using? Have you fully optimized this computer, done every little optimization step, however annoying? Go check they are still all made. See your Pro Tools install doc, or the "help us help you..." link up the top of this page. And you never said what the playback engine buffer size was set to, make it as large as you can and see if it at least gets stable. Oh and uncheck "ignore errors" -- you want errors to be thrown if there are problem report the exact DAE error number/message here. That can help isolate issues. |
Thanks for the tip! My harddrive and Optic Drive both were from a previous computer that ran pro-tools smooth with minimal lag.
If you want to fix this problem in the minimal time get a proper spec audio/session disk installed and see if the problem is fixed. If you want to waste time, just kid yourself you *know for sure* it is not the disk... Next question... |
Protools 9.0.6 'static on playback' & no PT Headphone playback | vcoad | Windows | 1 | 03-14-2013 04:09 PM |
Playback Problem: Overpowering Static Noise: Pro Tools can not get playback fast enou | JLue | Pro Tools 9 | 1 | 08-04-2011 08:59 AM |
Fuzzy Static with ProTools playback and window media files playback | 39lashesmedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-25-2011 05:41 PM |
Static "Playback" with Protools and Static "Playback" with windows files | 39lashesmedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-20-2011 05:57 AM |
g4-400 bogs down with plugins!!! | A Chadwick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 06-19-2001 03:23 AM |
