Old 12-17-2008, 05:28 PM
smc917 smc917 is offline
Default Kontakt 3 Outputs in Pro Tools LE?
How do I get more than a stereo output of Kontakt 3 when I use it as a plug-in in Pro Tools LE 7.4?
I have it working but only with stereo channles.
I see the configure button at the bottom of the channel strip in Kontakt3 and I can access it but I don't see how to add more stereo pairs?
Thanks.
Old 12-17-2008, 05:31 PM
peppertree peppertree is offline
Default Re: Kontakt 3 Outputs in Pro Tools LE?
Don't remember how to config the outputs in Kontakt itself, though it usually isn't hard. The outputs show up in Pro Tools as if they were analog or bus inputs (you make a new aux input channel and you will see them in the input menu).
Old 12-17-2008, 07:05 PM
gdugan gdugan is offline
Have you read Chapter 12 of the Kontakt Manual, "The Output Section"? I wonder if your answer can be found there.
Native Instruments-Kontakt 5-Abbey Road Modern Drummer-Separate Outputs to PT11 martinaston AAX Plug-ins 14 11-28-2013 11:19 PM
Routing to unassigned Kontakt outputs Starting User macOS 1 10-28-2012 02:05 PM
Kontakt 2 Multiple Outputs Safjuan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-05-2008 08:21 AM
Assigning Kontakt outputs to Instrument track in PT sky88dd Virtual Instruments 0 09-27-2007 03:34 PM
Multiple outputs with Kontakt in 6.7? jstaczek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-24-2005 10:57 AM
