  #31
Old 11-06-2014, 08:49 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: EuCon Hell
Wow, this is crazy. Sorry about the surface not powering on! To set up a repair call 650-237-1700, then option 4, then option 3.
Great news about getting EuControl to launch though. Please follow up when your surface is repaired. Hopefully, things will be smooth at that point.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
  #32
Old 11-07-2014, 07:32 AM
unkewl unkewl is offline
Thank you, Kyle! Will report back...
PT 2018.4 HD / Mac Pro (Late 2013) MacOS 10.12.6 / 3.5 GHz 6-Core Intel Xeon E5 / 16 GB 1866 MHz DDR3 / Mac SSD / Thunderbolt Display / LaCie 5big (JBOD) / 2x-Focusrite Saffire Pro 40 (Dual Unit) / Avid Artist Control
  #33
Old 12-15-2014, 09:35 PM
luisalonso80 luisalonso80 is offline
Im following this thread because Im having the same problem... will keep trying some stuff here.
  #34
Old 12-15-2014, 10:50 PM
I notice this just happened after upgraded protools 11 hd to the latest, before was pt 11.1.2 , and i just upgraded yesterday and problem started, I hope this helps.
  #35
Old 12-15-2014, 11:21 PM
well, I downgraded eucontrol to 3.1.0(next down) same thing with protools to 11.1.2, and so far problem solved, working flawlessly. Will stay there for a while, I love stability.
  #36
Old 07-23-2015, 01:11 PM
Checking back in... Sent Artist Control to Avid for repair (finally), upgraded firmware... And I am in Fader Control Heaven.
Thanks all!
  #37
Old 11-28-2015, 01:54 PM
wene wene is offline
Hi all
I got the mentioned connectivity issue just sorted out just by following this thread. So many thanks for the distributors before me!
To put it in short:
I went from the Finder
/go/Go to folder...
and from there I typed
/usr/local/
From upcoming window, you should see folder labeled "lib" with tiny red minus tag.
Right click the "Lib" -folder and "get info"
From the upcoming window choose "Sharing & Permissions" at the lower part of the window, and check that you (username) have Read&Write access to the "Lib"-folder. If the access is missing, just create it from the "+" sign at the lower left and give it read&write access. If there are entries in the Sharing & Permissions list for users or groups besides "me," "staff," and "everyone," delete them.
Hopefully this helps you too!
References:
MBP 10.10.5 (14F27) Yosemite and PT 12.3.1 + iPad with PT Control -software is the environment I'm in.
https://discussions.apple.com/thread...art=0&tstart=0
https://app.box.com/s/6agt4wnu5ikxmedg3cf6
(..and http://duc.avid.com/showthread.php?t=353145 too)
These are my principles - if you don't like them I have others.
G. Marx
  #38
Old 03-11-2023, 11:36 AM
cjtowner cjtowner is offline
This is an old issue but not enough info out there on a solution so I thought I would create a post for Macs, maybe can figure from this if you have a PC.
I mistakenly installed the Avid EUCON 3.1.2 because I was looking for iPad control for my ProTools IO interface and it crashed ProTools IO interface and caused issues for LOGIC Pro, here is how I resolved it.
Macintosh HD > USERS > shift + command + . Then see screenshot for path
Delete these two files below (culprits) as well as the rest of the EUCON and EUPHONIX files I found on the computer in other screenshots.
libEuCon2.dylib
libEuConDLL.dylib
  #39
Old 03-16-2023, 08:08 AM
dominicperry dominicperry is online now
Well done for reviving an 8 year old thread, and posting the largest image files possible.
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 01:37 PM
DFH - drumkit from hell - installation from hell!! polf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-01-2011 07:57 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
Drumkits From Hell? Install From Hell. Sparks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 04-13-2005 06:11 AM
